Home Forums Sign Making Discussions General Sign Topics Gerber spooling problem
  • Gerber spooling problem
    Posted by Saph-D on 13 August 2007 at 21:25
    Hi folk
    I have recently bought a Gerber Edge and cutter and am slowly slowly working my way through the massive manual with it. I have a few areas where I am having problems but know that these will resolve with time and practice.
    However something has just happened which has thrown me. I printed and did an outline cut with no problems – although I wasn’t delighted with the colouring – because of this I printed a different image using process colours rather than spot and was thrilled with the outcome.
    I lined it up okay, sent it to the cutter and got an error message saying that I have a communications problem – to check cables etc. Everything is connected okay, I can move the blade around and align the registration mark etc – i don’t understand why this has suddenly happened.
    I have rebooted the pc, switched off the cutter etc – is there something that I should alter or check in system devices ? Any advice or suggestions would be appreciated 🙂
    Thanks, Saph
    Chris Lambe replied 18 years, 4 months ago 2 Members · 2 Replies
  • Saph-D
    13 August 2007 at 21:42
    Not sure what has happened, but I have done something and it is working again 🙄
    Will be interesting to see if it happens again. Obviously my computer settings I think.
    Saph
  • Chris Lambe
    14 August 2007 at 07:17
    quote Saph Van Duyn:
    Saph
    Hi i have a gerber edge also and the only time i have had this problem was a cable issue so i’d say your fiddling with the plotter cable did the trick
