Activity Feed › Forums › Sign Making Discussions › File Swapping › Gerber / Spandex .plt files
Posted by Nigel Pugh on February 14, 2005 at 9:20 pmApart the software that created it what would you guys n gals use to open plt files.
Tried the plt filter on Flexi and it sees the file but when you think you have imported it there is nothing there, had a go with Corel 11 with no luck either.
Thanks in advance for all help received.
Nigel Pugh replied 19 years, 2 months ago 5 Members · 8 Replies -
If you want I can open it for you and save it as something else – eps or ai. Drop me a pm and I’ll sort it out for you 😀
Nigel
Excuse my ignorance, but why would you need to open in anything other than it’s creator file????
If you need to open a .plt file in flexi(why?) use the save as command from Gerber and save as an .eps, .ai or whatever flexi can accomodate.
Because i can’t get ‘me stupid head around Omega ,i tend to do most designs in Flexi (easy distortion to pre defined shapes etc) and then export to eps or ai, (whichever i fancy)in the wireframe mode and then fill from within Omega and tweak if needed JD.
P.S I would like to be able to print from Flexi(driverss are there i know, but can’t get it to ‘talk’ to the Gerber………anybody??)
Darryl
Darryl the reason behind the question is that a customer has sent me a plt file and I do not have any software that appears to open it.
Oh Nigel what software will you be using to open this file?
Nige(admin-edit) file swapping or file requests must only be done in file swapping forum.
aha !
now i see !Nigel would be using the Omega programme and then exporting for a guess. i believe from memory that he uses a Gerber.
darryl
Yes thats right Darryl – I would open in Omega and then export as eps or ai and make sure it imported into corel to check the dodgy gerber software has done its job 🙄
Nigel
Is that a kosha copy U usin of Flexi then if not then maaayybbeee thats why it wont print.
skuzzzee me If I am wrong.
Goop
Rob,
Fair enough I understand why this post was moved to this forum but it did start off I would have thought in the General Topic forum correctly as I was just asking a question regarding ways of opening a particular type of file and not directly after file swapping.
But why has my e-mail address been taken out?
Nige
