Home Forums Vinyl Cutter Discussions General Cutter topics Gerber expert wanted
  • Gerber expert wanted
    Posted by Afon Displays on 17 October 2003 at 22:21
    I have a challenge with an imported eps file from a corel 10. I have converted the file so it will open in the gerber program, but when I want to select and plot there is no image just a cross in green, 😕
    Henry Barker replied 22 years, 2 months ago 4 Members · 4 Replies
  • Andy Gorman
    17 October 2003 at 22:43
    Which Gerber program? Advantage?
    I always used to export as an .ai(ver 1.0) for vectored images from corel 9 and tiff for bitmaps.
    Worked perfecto.
  • Afon Displays
    17 October 2003 at 22:51
    Hi Big G, it is a gerber scientific product – omega,
    Ian 🙂
  • keith
    17 October 2003 at 23:53
    Ian,
    you could try exporting it as a plt file to a drive then open it in omega and save it back as you would ordinarily do.
    We have the same problem with advantage.
    The other way is to ungroup, then give everything a very small outline and delete the imported line. This although labourious works for us.
    Just an idea.
    Keith
  • Henry Barker
    18 October 2003 at 08:46
    Omega can sometimes say unknown file format importing eps files from Corel or Illustrator.
    Open in Corel save as ai, convert text to curves, and make sure you save up as high as Illustrator 6 and it should open fine, you can try to open as print or cut colours.
    Any problems send the file to me and I will try and fix it for you.
