General Ink Usage Question
Sorry if this has been covered before as i suspect others have probably brought this up before.
I know there are loads of variables in ink usage, but as a general rule, how many square metres of vinyl would you expect to print using a full set of cartridges, before having to replace them?
As an example, our machine is the Roland SP540v, max inks etc, we mostly use 1370mm white vinyl for printing. Can i expect to print a 100 metre roll of vinyl before running out? or maybe half of that is more realistic?
I think my ink usage may not be running in tandem with what i’ve been told, so it would be nice to have ‘a good idea’ of how much print i should get through with 220ml carts.
I’m guessing most printers of this type of range should be similar-ish?
