Home › Forums › Printing Discussions › General Printing Topics › Geber Edge just died – any ideas?
Posted by TimDouglas on 9 December 2010 at 08:49My Edge just died this morning once i started it it registered itself then just turned off ? Could it be the fuses? are they standard fuses or do they need to be ordered in? Any help would be good as I need it today as normal!!
TimJason Davies replied 15 years ago 6 Members · 12 Replies -
If you look at the Main board , there is a small glass fuse, cant remember the ampage 1.5a i think. Check to see if it’s blow, any motorfactors will have one
Ian
Just checked its OK as well, we replaced the 3amp fuses in plug and they blow, put a 10amp fuse into the plug and then the 2 on side of machine blow, is there any Engineers in Northern Ireland that would work on them that you know of Ian?
Tim -
Hi Tim, it’s the power supply, same thing happened to me a couple of months ago – Spandex/Gerber job unfortunately – not cheap.
Jason
Thanks Jason, had a mate check it out, Power supply dead!!
Tim -
Tim -
The power supplies are from Delton power supply in the States. There is someone in the States (California) but I can not remember the name that rebuilds them.
Its with a company at the minute , I will update you with the result,
Tim -
Might be a bit late now….
Where the power lead goes into the printer, there is a small fuse there, is this the one you are talking about?
I got a couple from Maplins..
we had swapped out power unit twice, once with Spandex UK and that did cost (this was before my time there) and then again but this time my MD’s uncle who is an electronics engineer fixed it, pretty much replacing all the parts for a quick fix.
I have to admit, it isn’t an easy thing to fix as you might find Spandex are more interested in selling you a new machine.
Spandex were brilliant but you will have to wait, mine took two weeks to be fixed, unless you have a maintenance contract.
