Activity Feed › Forums › Sign Making Discussions › General Sign Topics › Gatorfoam help
Gatorfoam help
Posted by Nancy Wannous on August 14, 2006 at 10:39 pmHi guys,
Has anyone used Gatorfoam ever .I need some info about it and also how to handle it cut it etc… and also can it be used outdoor or is it only indoor does it expand?
Any info might help .
Thank you lots
NancyIan Hatfield replied 17 years, 8 months ago 5 Members · 10 Replies -
hi nancy 😀
heres a thread on it https://www.uksignboards.com/viewtopic.p … =gatorfoam
hope it helps 😉
Hi Nik,
Thank you for that but it doesn’t say much about how to handle it the board is kinda strong but cutting it is nasty. i can get it as one sheet the cost is about $130 aus for black color.The thing is my client gave me a sample and he said that foam core but to me looks like gatorfoam. i did some search on google. though if anyone worked with them before that might be helpful
Nancy -
nancy if shane says its paper faced and light…..it will be like the kappa board i used to use years ago…….. 😀 hopefull it is and its so easy to cut with a stanley knife 😉
the thing is i tried with the stanley knife and the edge went like powdery it needs to be clean cut cos they will be like used to mount the posters A1 A2 and A0 sizes 🙁
yap but it doesn’t go through from first cut i have to do multiples. 🙁
Hi Nancy,
Have never used Gatorfoam yet, but it is a product of Alcan Composites (formerly Allusuise) and this means most of times that it is a top quality product. I know it is used very much in the US.
You can find more about it at This link.
They say medium term outdoor.
Cutting is not recommended, you will need a saw or router.Hope this helps you a bit.
Regards,
JJ -
quote wannousnancy:Thank you JJ. Looks good Thank you Nik also.
NancyHi Nancy.
Gatorfoam is hard stuff to cut smooth Nancy. You need a neolt trimmer to do a perfect job. I have a keencut which is good too, but it still talkes a few cut or else it crumbles on the edge.
The stuff JJ is talking about is the sample fourex I sent you earlier in the year.
You may be better buying some 2mm ePVC? Cuts with a stanley, and is light weight.?
Sorry can’t be any better help.
Gatorfoam is hard to come by in the UK I have tried to get it in the past. Kappa Board do a Kappa plast which is nearly the same it has a plastic face like gator rather than the paper/card face. I think Cox plastics still do it.
Ian
