Home Forums Sign Making Discussions Neon, LED, Lighting Freestanding Post Sign with light solutions?
  • Freestanding Post Sign with light solutions?
    Posted by Pryam Carter on 23 February 2008 at 09:25
    My client has requested that we install an illuminated post sign at the entrance of his caravan park. He wishes that we make it from aluminium products (dibond, galv posts, rails, clips etc…). Easy enough.
    However, i cannot figure out the best way to fix a trough light at the top of such a sign, has anyone got any good ideas for me to try?
    Pryam Carter replied 17 years, 9 months ago 3 Members · 3 Replies
  • Graeme Harrold
    23 February 2008 at 11:20
    Have a look at these for inspiration………http://www.tradesignz.com/index.php?cPath=1004
    If you already have the lights, then you will have to manufacture the brackets yourself, most likely. Probably have to make another rail between the posts to mount from.
  • Martin Cole
    23 February 2008 at 19:10
    Pryam,
    I did one of these just before christmas. We left about a 150mm space above the panel and the top of the post to which we attached the brackets to hold the light. We used 400mm twisted brackets from Portland lighting.
    We drilled a hole in the post at the top and fed the cable down with another hole at the bottom for the cable to come out.(this was done prior to erecting the posts.
    Hope that makes sense, I can’t attach pics here so will put a couple in the portfolio section so to make it a bit clearer 😕
    Martin
  • Pryam Carter
    23 February 2008 at 21:59
    I hadn’t thought of this one, definately worth considering Cheers Martin.
