Home Forums Software Discussions General Software Topics Fool proof way of getting a cutline – recommend software?
  • Fool proof way of getting a cutline – recommend software?
    Posted by Paul.Gadsdon on 21 September 2014 at 18:27
    around a bitmap such as a jpg file
    Is there any specific software to help with this?
    Its easy if its an EPS or .AI file using path > offset path but when the image I need to cut is a bitmap file its well hard
    Martin Pearson replied 11 years, 2 months ago 4 Members · 4 Replies
    21 September 2014 at 18:56
    yep it is, but hours of practice pays off in the end.
  • Karen McGinty
    21 September 2014 at 19:03
    Hi.
    I use CorelDraw personally! You need to duplicate the image on a 2nd page, click on bitmap tab at top, then mode and convert to b&w image. (Try and get as much as the image to convert to black so it gives a clear outline where you will want to cut!) Then trace the bitmap image, until the image and change the outline to what your cutting programme recognises as a cut line before cutting and pasting this outline back on the original image on page one!
    It’s quite simple once you’ve done it a few times!
    Good luck!
    K x
  • Andy Coles
    22 September 2014 at 08:26
    Try installing Vectormagic, great program and will do it for you.
    22 September 2014 at 10:34
    As Dave has already said learn to use the software you have, spend 15mins a day learning how to use the drawing tools & node editing within what ever software you are using & before to long you will be doing this with ease.
