Home › Forums › Printing Discussions › General Printing Topics › Folex laser sheets.
Folex laser sheets.
Posted by ian rankin on 13 August 2004 at 19:39Nik, reading a previous topic I see you use these type of sheet for making positives from a laser printer. Could you perhaps help me with the name of a supplier and rough idea of cost. I have a Panasonic laser and I would like to use it for this purpose.
Thanks in advance Ian Rankin
Nicola McIntosh replied 21 years, 3 months ago 4 Members · 8 Replies -
if you give me twenty minutes ian, i’ll away to workshop and get info!!
Nik
well what do you know!! went over to workshop came back and caught a trojan virus!! 😮 i hate those things!! 😀
anyway here is info
comapny is ipm technology ltd
unit 11c dawkins road ind. estate
hamworthy poole bh15 4jp
tel. 01202 845977agfa laserlink film A4 100 sheets per box double sided
i also use the fern high density spray for 400ml it’s £9.99 plus vat you spray over print to densify the black!! (you probably guessed that) 😮hope that helps you out!!
Now thats what I call service. Thanks for the info I’ll give them a call.
So they have a spray to blacken the print I wondered if it could be dense enough.Thanks again for the prompt reply.
Ian Rankin
Ian Rankin
hi ian
they don’t guarantee the spray to work with every printer!! it works okay… with mine, it does blacken it a bit, but it might work better with yours !! 😛 good luck!!
Nik
I have been using the laser film for years.
Buy mine from
Colenso screen services, tel:01928 701356
matt translucent film, 75 mic
100 sheets of A4 – £18.07
100 sheets of A3 -£36.14Onced printed on get some white spirit and wipe over it with a damp cloth.
then dry it with a hair dryer.real dense black.
Also consider buying a A3 laser printer.
I use Autotype Delta film from Imaging Direct 01296 630111. They also do a film enhancer which when warmed makes the image very black, a bit pricey but is slightly more effective than white spirit. I use the film for litho printing work.
Alan -
never tried turps!! but will give it a go!! 😀
thanks for the other contacts folks, nice to keep the pencil sharpened!! 😉
Nik
