Home Forums Software Discussions Flexi Sign Software Flexisign & MAC OS 10.5
  • Flexisign & MAC OS 10.5
    Posted by Neil Davey on 10 June 2009 at 12:28
    Hi, thinking of upgrading from my MAC G4 Quicksilver to a new Imac.
    Just wondering if anyone knows if Flexisign 7.5 will run on the new Imac with OS 10.5 or will I have to upgrade to Flexi 8.0 for MAC as well.
    Flexi works OK on my Ibook with OS 10.4.
    Thanks Neil
    John Childs replied 15 years, 8 months ago 8 Members · 21 Replies
  • 21 Replies
  • John Wilson
    10 June 2009 at 12:58
    Nope
    I bought Flexi 7.5 and it won’t run on my mac because it’s intel based but the 8.0 does
    Give them a phone and they will give you an upgrade price though
    10 June 2009 at 13:25
    John, it’s probably irrelevant now but I thought Flexi had always been available in either a PC or Mac format, you just had to buy the version you required.
  • Neil Davey
    10 June 2009 at 13:44
    Thanks John & Martin, my question was probably a little misleading but I’ve always run Flexi on a mac but really don’t know if 7.5 runs on MAC OS 10.5.
    Perhaps I’ll ring Granthams or someone!
    Just wondered if anyone at the sharp end knew the answer.
    Cheers Neil
  • P. Harris
    10 June 2009 at 14:17
    Hi Neil, I was told by GraphtecGB (main Uk distributors for FlexiSIGN)
    That I if I Upgraded my G4 from 10.4 to OS 10.5 I would also have
    to upgrade to version 8.5 of FlexiSIGN!
    Like anything now a days always costs you double!!
    Give GraphtecGB a Call or Go onto ScanvecAmiable Web to Double Check.
    Hope This Helps
    Cheers Brock
  • Neil Davey
    10 June 2009 at 16:14
    Cheers Brock, as I anticipated. 😕
    Neil
  • Barry Williams
    19 July 2009 at 12:42
    quote Neil Davey:
    Thanks Neil
    Neil
    why not format the HD on your new iMac
    abd then install the earlier 10.4 OS?
    That is, if you are not trading up simply for the new features in 10.5.
    OR If an Intel based iMac, perhaps it is possible to just re-partition the drive and instal the OS 10,4 of which you prob have the discs , onto one dedicated partition and run Flexi 7 in that , setting the Mac to startup in that OS.
    BARRY
  • Nic Bessent
    11 August 2009 at 17:18
    i had a imac running 10.4 and flexi 7.5 – had nothing but problems for a year with crashing so they upgraded me free to 8.5 pro for free as they said there were know problems…………..
  • Neil Davey
    11 August 2009 at 19:58
    Well, I’ve upgraded everything. I’ve got a new Imac 24" and Flexi 8.5.
    I’ve also installed VM Fusion so that I’m running XP Professional to accommodate my accounts and estimating programs. And I’ve installed Omega to run my Edge FX so things are alot easier. I can now design in Flexi and just drag the file into omega to print.
    Also cuts out the need for 2 computers.
  • John Wilson
    25 January 2010 at 20:56
    Any further ahead on the software
    I wouldn’t mind a trial
  • Neil Davey
    25 January 2010 at 21:23
    Ditched Fusion for Parallels as I found fusion very slow when opening, very very slow.
    The only annoying thing with Parallels so far are the usb devices,
    dongle, plotter etc aren’t loading when opening so I do it manually.
    It’s ok as it’s something I just do now but I’m trying to figure it out.
    Of late, my Imac has been suffering from a lot of Kernel Panics but I traced it to the Flexi dongle and I’ve updated the driver and, fingers crossed, we haven’t had a panic since.
    Apart from that it all works great. 😀
  • John Wilson
    29 April 2010 at 17:27
    Does anyone know of any way I can get a trial version of 8.5 for the mac… don’t want to just buy it without at least trying it for a while as a trial
    Fed up running windows on my mac as it’s always too too slow
    29 April 2010 at 18:48
    who said macs dont have problems?
    just use a pc
    problem solved 😀
  • John Wilson
    29 April 2010 at 19:40
    Macs have very little problems, mostly due to software but easily solved if find the right mix
    I’m using windows on my mac, nothing but errors… funny enough the same errors I get on a standard PC
    29 April 2010 at 20:11
    quote John Wilson:
    Problems on a pc? never had any yet.
    fires up, does the job.
    like you say its down to software,
    why do you need to emulate windows if mac is so good?
  • John Wilson
    29 April 2010 at 20:17
    Because most signage software isn’t available on the mac
    29 April 2010 at 20:25
    quote John Wilson:
    so why do you think that is? why not buy a pc that will run most sign programs?
    why buy a mac if you cant run the programs that you use?
    adobe runs on a mac so you only need a rip/cut program on mac to solve your problem, stick to mac if you prefer, cant see why you need to use pc programs as well?
  • John Childs
    quote John Wilson:
    But Typestyler isn’t available for the PC. 😀
    29 April 2010 at 21:01
    quote John Childs:
    quote John Wilson:
    why would that be an advantage for a mac?
    just asking, it looks like a good animation program, but how useful for signage?
  • John Childs
    29 April 2010 at 21:10
    quote Peter Normington:
    Animation? Are you looking at the right Typestyler?
    The one I mean is a brilliant tool for creating logos, layouts, and all the sort of text effects held so dear by users of SignLab and Flexi. But it does them better, and at a fraction of the price.
    http://www.typestyler.com
    29 April 2010 at 21:30
    John I was looking at the video effects that typestyler can create.
    didn’t look closer, It does look very good,
    I will have a closer look,
    doubt if I will need a mac though, to create similar results..
  • John Childs
    29 April 2010 at 21:53
    Nah, I’m sure you can do it all in Signlab. Albeit at ten times the price. 😀
    Seriously though, I’m not sure how TypeStyler stacks up as a stand-alone programme, or if it’s even meant to be one, but when used in conjunction with Illustrator, it is a very powerful piece of software.
    I’ve been using it on and off for twenty years, although back then it was only for text manipulation as the print effects were of no use to me as a pure vinyl cutter.
    That’s all changed now with our acquisition of a printer, and opens up a whole new world of cuttable printed decals.
