Flat Sign on top of wall????
I have to fix a sign up on top of the wall, The sign will be 10mm foamex exterior, and the sizes are 250cm wide, and 50cm high. The sign is to sit on top of a ledge on top of the wall.
I was thinking some kind of "L" shaped bracket screwed to the top face of the ledge and the screwed to the upright sign. One at either end, one or two in middle, what do you think. Or is there a better way, diagrams attached, very technical, lolhttp://www.uksignboards.com/viewtopic.p … 859#183859
