Activity Feed › Forums › Sign Making Discussions › General Sign Topics › Fitting window graphics when the window is cold
Posted by Denise Goodfellow on November 29, 2018 at 6:28 pmSent the lad out today to fit a couple of small window graphics… and he failed.
First he couldn’t set the job up on the window, no tape would stick, he tried Hexis masking tape, electrical tape, parcel tape and strips of vinyl. Nothing would hold the graphic to the window.
Any thoughts on what else can we try. Don’t want to heat the window up with a heat gun Incase the glass breaks
Hugh Potter replied 5 years, 5 months ago 7 Members · 10 Replies -
If nothing holds to the glass, then no point in putting the graphic up is there ?
Sounds like the glass may have been cleaned with s silicon based product. Has it been cleaned properly? -
Hi Denise
Try covering the other side of the glass with bubble wrap, great way to insulate the glass without risk. -
quote Iain Pearson:If nothing holds to the glass, then no point in putting the graphic up is there ?
Sounds like the glass may have been cleaned with s silicon based product. Has it been cleaned properly?Cleaned with ipa several times
Only way I’ve got round this is to warm the glass slightly. Not idea especially outside but surprising the difference a little bit of heat make. Do piles of car window graphics for a local garage and have to heat both before and after application. Only had one fail and I swear they power washed it off!
was it a hair salon or barbers? They’re the worst as you can’t clear the mist off quick enough, if it’s cold outside your own breath with be your enemy!
I’ve done it using lots of Isprop to clean and then held in place using 2" clear parcel tape (not the brown stuff) and squeegee it down, usually works.
Obviously don’t do it wet and when peeling back the hinge (ask someone to hold the exposed bit) clean the glass again with iso to remove moisture and apply right away. removing the app paper can be tricky and care needs to be taken there!
quote Hugh Potter:was it a hair salon or barbers? They’re the worst as you can’t clear the mist off quick enough, if it’s cold outside your own breath with be your enemy!
I’ve done it using lots of Isprop to clean and then held in place using 2″ clear parcel tape (not the brown stuff) and squeegee it down, usually works.
It was a salon
Done today, went mid day when It was a bit warmer. Packed every tape known to man.
Packing tape ( not brown type) won the day. -
Has anyone tried using one of those Karcher window vacs for this type of install. It’s technically steam cleaning the glass & drying straight after, might be worth £50 on a punt unless anyone else has already tried it?
We use Karcher vacs but all they do is remove moisture from windows rest have to be done mamually no steam cleaning element there I’m afraid.
quote Martin Lemiesz:We use Karcher vacs but all they do is remove moisture from windows rest have to be done mamually no steam cleaning element there I’m afraid.
Apologies, got the brand wrong, not Karcher, it’s an Ovation hand held steam cleaner. I don’t think it vacuums the window though
quote Denise Goodfellow:quote Hugh Potter:was it a hair salon or barbers? They’re the worst as you can’t clear the mist off quick enough, if it’s cold outside your own breath with be your enemy!
It was a salon
Packing tape ( not brown type) won the day.That’s what I meant when I said 2” cellotape !! Only thing I e found that’ll stick long enough!
