Fitted a set of suppliied orafol graphics to a truck
Hi all.
I fitted this lorry today
Graphics were supplied by another company as this is a nationwide firm.
Everything was printed with orafol and it had grey backing.I only use Avery ansd dont use grey back.
Normally with something this size i would start from the middle, lay with a dusting of water so it can be put in place before i lay it. Because this was grey back it didnt feel very tacky so i was concerned with doing it wet. I ended up starting from the left, layed the first half metre then worked my way along, all dry. Obviously an issue with this could be running out but it turned out to be just 1.5mm which im happy with over this distance.
Nothing had any joins it was all one piece.
Any of you guys use orafol? what would you guess this material range is? and how would you have tackled this?
