Home Forums Sign Making Discussions General Sign Topics First time putting up cut acrylic letters using locators
  • First time putting up cut acrylic letters using locators
    Posted by James Boden on 3 November 2015 at 20:31
    Hello peoples,
    It’s my first time putting up acrylic lettering using locators next week. Can anyone offer some words of advice or point me in the right direction of useful videos 😀
    Thanks in advance.
    Ewan Chrystal replied 10 years ago 13 Members · 29 Replies
  • 29 Replies
    3 November 2015 at 21:10
    Make sure you have screws that will fit down the locator, without distorting it. Especially if you’re using the smaller ones.
    Also helps if you have an adaptor for your screw driver, that will fit down it too.
    Fit the template, and drill the holes marked on the template, being as accurate as you can.
    What kind of surface are you fitting them too?
  • James Boden
    4 November 2015 at 07:56
    Hi David, thanks for that. The surface is wooden
  • Gary Birch
    4 November 2015 at 08:07
    I always pilot drill the holes even into timber. Also, don’t nip the screw up so the cup is tight. Ideally, the cup will spin freely on the screw.
  • James Boden
    4 November 2015 at 08:23
    Thanks Gary
  • Ewan Chrystal
    4 November 2015 at 15:46
    Can i hijack this thread if you don’t mind as i have a similar query.
    I’ve got a similar job coming up and i’d like some help with the set up if possible.
    The letters are 700mm high and 10m overall length. I’ll have a cherry picker on hire for this. My question is really to do with making sure i put everything on straight and level. For something this size how would i go about marking it out? Would a string line be suitable for this or do you think a laser level would be better to get a straight line? And what about things like fixing the template in place? Its going onto a flat stone building btw.
    Any advice would be much appreciated
    4 November 2015 at 15:53
    Out fitters did some built up letters last week, about the same size in height, but 5m wide.
    We produced the template on 4mm correx, printed and trimmed out square.
    Marking the centre of the sign on the template, enables them to fit the centre first, get that straight, then work our from there.
    With each panel being square, they just measured it and butted them up.
    I hope that makes sense.
  • James Boden
    4 November 2015 at 16:43
    No problem, hijack away..
    I think this is my concern too – getting the letters as straight as possible. The actual process attaching them doesn’t seem too complex.
    Thanks for the advice so far 😛
  • Ewan Chrystal
    4 November 2015 at 17:01
    Ah right, so you/they didn’t use the paper template on the wall?
    4 November 2015 at 17:10
    Ours was being fitted outside, so we opted for correx, in case it rained or was windy.
    Was the installers idea not mine. :lol1:
  • Iain Pearson
    4 November 2015 at 18:20
    Hi Ewan
    I always use Foamex templates outside where possible.
    It’s very durable, can be cut to size and squareness, butted together to form very large stub outs.
    If it rains, and you use paper, you will end up with a soggy mess on the floor and a client with no letters on their building :lol1:
    If you need any advice, feel free to give me a call – 07881627231
  • Ewan Chrystal
    4 November 2015 at 23:18
    Cheers Ian will do closer to the time thanks
  • Simon Worrall
    7 November 2015 at 07:36
    I too have used all manner of things for templates.. Correx (Corflute in this part of the world), paper, cardboard, vinyl backing paper, and possibly the easiest to use I have found is cheap removable exhibition vinyl.
    Simon
  • Steve Maple
    8 November 2015 at 23:15
    hello
    use button head screws
    leave the protective film on the face until you have fitted them
    IF there is no protective film on them, considering you are a novice, take extra care
    in making sure you have the letters the correct way around before sticking the males on.
    I.E. make sure the ‘c’s are the right way up and the ‘U’s are not back to front – plus all the others.
    when you are pressing the letters into your drawing, make sure you are looking directly down on them.
    note the locators are made from PVC and not acrylic
    don’t use tensol to stick them as the you will see the tensol glue shrinkage through the face
    before you start glueing them on…. tape down some 60/80 grit glass paper on the bench, count out
    how many you need – at least 3 per letter, m’s and w’s want 4
    sand the surface to be glued – there is always a bit of flash on them and the sanding helps the adheision
    when about to glue, spin your thumb with some glass paper in the area you wish to glue to roughen the letter
    try not to place them too close to the lower edge, as you don’t really want to see them
    the most important this is to mark similar letters on the back 1-2-3 and on the template to correspond.
    https://www.google.co.uk/maps/@51.47202 … 312!8i6656
    I didn’t do this but I laugh my tits off every time I pass……..
  • Martin Cole
    9 November 2015 at 09:42
    quote Steve Maple:
    I didn’t do this but I laugh my (oh i swore !) off every time I pass……..
    That’s a shocker 😮 it’s normally the S’s
  • Sean Graham
    9 November 2015 at 13:56
    Like the S when the Sir Alex Ferguson Stand was revealed
    http://i.dailymail.co.uk/i/pix/2011/11/ … 34×286.jpg
  • James Boden
    22 November 2015 at 20:42
    Thanks for the advice peoples. The installation went up without a hitch 😉
  • Unknown Member
    22 November 2015 at 21:23
    Looks great James!
    Well done buddy!
    23 November 2015 at 18:28
    Looks pretty good to me.
    Easy when you know how isn’t it James, my only criticism is your choice of picture, suppose to be one of you working hard not standing about drinking tea :lol1: :lol1: :lol1: :lol1: :lol1: :lol1: :lol1: :lol1: :lol1: :lol1:
  • James Boden
    23 November 2015 at 20:23
    Hey Martin, don’t knock it. That tea was well deserved!! 😛
  • Iain George
    23 November 2015 at 20:53
    Looks good but , I just zoomed in, why did you number the letters on the front? I you put the numbers on the back you don’t have to worry about cleaning if all off at the end.
  • George Elsmore
    24 November 2015 at 08:53
    quote Iain George:
    If the protective film is still on does it make any difference? 😕
    well done pal
  • Iain George
    24 November 2015 at 16:06
    quote George Elsmore:
    quote Iain George:
    well done pal
    When ever I have had these supplied by a trade supplier the numbers have always been on the back even with protective film on the front.
  • Steve Maple
    22 December 2015 at 13:24
    the halogens may melt those letters 1000 watts will.
    all looks a bit low.
  • Ewan Chrystal
    22 December 2015 at 16:56
    Heres the one did. This was my biggest install to date. 10 metres long for the stand off letters on the front of the building using correx templates. The side of the building is painted on and for this used foamex templates @ 4.2m x 2.6m
  • Unknown Member
    22 December 2015 at 19:22
    Ewan….
    Damn that was a big old job…
    Well done to you mate.
    How did all the templates work in the end for you?
    22 December 2015 at 21:10
    Nice job Ewan.
    I am 99% sure I have been in that place a few times, if its the place I think it is…
    Over the stone bridge and got a big sailing ship moored up on the loch?
  • Ewan Chrystal
    22 December 2015 at 23:19
    That’s it David. My home town.
    James they worked a treat. Had to trim the tops off the big one to fit under the sills but other than that went s fine.
    In hindsight I should have used masking paper for the smaller ones as the paint kept bleeding behind the template. I ended up painting over it and used cast vinyl for the letters but was all a learning curve. Thanks again for your help and advice
    23 December 2015 at 05:52
    What a small world and lovely place to live. I keep meaning to revisit that neck of the woods.
    Did you hire a platform for the installation?
  • Ewan Chrystal
    23 December 2015 at 23:55
    Yeah 17m tracked Cherry picker. Great machine
