Home Forums Software Discussions General Software Topics files….Ai…..eps…whats gone wrong
  • files….Ai…..eps…whats gone wrong
    Posted by Brian Little on 24 September 2005 at 14:38
    hi folks just a quick question . I run signlab 4.95..a great tool very reliable..usually .But ive noticed probs lately with opening files. when i open ai files sometimes i dont get the full logo or what ever it is customers sent me . If i drop it into signlab 7 (demo version) it opens no probs (?) . Ive also noticed that sometimes when i drop an eps file that ive been sent you can see it goes in by the blue line along the bottom of the screen ….but it aint there …it doesnt happen all the time which is even more confusing .Vehicle outlines are somtimes left without any detail i mean you can see the vehicle but no outlines just a mask so to speak
    any ideas
    Regards Brian
    i suppose i could re install but im always a bit paranoid about doing that just incase it doesnt work 😥
    Brian Little replied 20 years, 1 month ago 5 Members · 9 Replies
  • 9 Replies
  • Mark Candlin
    24 September 2005 at 16:14
    Brian, try opening the eps in illustrator or coreldraw first, if it looks ok export it out again as an eps or ai and then import it into signlab.
    I often found this helped.
  • Brian Little
    24 September 2005 at 16:44
    Mark have you had the same probs ?
    24 September 2005 at 17:50
    AI, EPS contain instructions that draw up how the image should look in your design program, normally SignLab programers etc sort this out, they don’t get it right. However Adobe who designed EPS etc., those programs normally open files correctly, however Corel is about 90% good for opening files.
    I know that doesn’t help Brian, thats just the way it works.
  • Gordon Forbes
    24 September 2005 at 18:01
    Tell the suppliers of the file to save it in an older version of eps or ai should sort it out I think.
    Read version 8 of .ai etc for signlab somewhere thats the newer versions
    Hope this helps
    Goop
  • Brian Little
    24 September 2005 at 18:06
    thanks people …i think the prob may be the fact i dont have illastrator or coral draw on comp …never used it …mabe id better get it
    regards brian :lol1: (?)
    24 September 2005 at 21:10
    Brian, its all to do with the age of the software you are using, as programs such as freehand and illustrator have developed they have changed to the point that signlab 4.95 now doesnt understand them anymore. The reason that the demo version of signlab 7 opens them OK is because it to has changed and one of the changes will be how it reads these type of files.
    The reason it doesn’t happen all the time is because some of your customers will still be using older versions of illustrator etc.
    The best way round this is to ask your customer to save the artwork in an earlier version of illustrator then you wont have a problem. I use inspire 1.6 and have a similar problem but I cant afford to upgrade inspire to flexi 7.6 which is what it would be now.
    Because I also use illustrator and have illustrator 10 I just open the files in that and then save as an earlier version myself.
  • Brian Little
    25 September 2005 at 07:06
    cheers martin thats been a great help …looks like im gona have to up grade like it or not ill have to move with the times .Im still on windows 98 and for signlab 7.1 theres no dought itll have to be xp
    Cheers martin
    25 September 2005 at 09:40
    Brian, I’m exactly the same. Its not a case of not moving with the times its really down to money, the upgrade from inspire 1.6 to flexi 7.6 would cost me a fortune and I just dont have that sort of money. I run windows 98se on my design computer because inspire wont run with anything more up to date. Inspire does everything I need it to as most of the work I do is straight vinyl so an upgrade although nice wouldn’t really be of much benefit to me at the moment.
    I have never used signlab so can’t comment on it myself but I do know that some people that use it say 4.95 was the best version made.
    There will come a time when I have no choice but to upgrade but at the moment there are things that I need the money for more than an upgrade.
  • Brian Little
    25 September 2005 at 10:36
    I couldnt agree more martin ……this game was so much easier when i was doin the lot with a set of pure sable writers and a tin of one shot .But the sign trades moved on ,so has technology ,looks like ill be forced to upgrade
    Regards Brian
    thanks for your imfo
