Activity Feed › Forums › Sign Making Discussions › File Swapping › file conversion help please
Posted by Cheryl Smith on April 20, 2010 at 4:35 pmHi,
ive got these files which were generated with a newer version than which I have..
would someone be so kind as to help me out by converting to a Corel 10 or AI10 for me in curves.
most most grateful
thank you for looking
CherylJohn Childs replied 14 years ago 3 Members · 13 Replies -
These should be ok Cheryl. I only have cs3 and so used my trusty ol signlab to convert them
just noticed that the bilstien one has some ugly blobs on the letters, I converted to PDF and its still the same, 🙁 looks like a bad trace from a JPG)
thank you so much for your time Peter…
rather infuratingly tho..ai goes to open them …i see a flash of the image and then it is not there …urggh
I may have to draw them 😕 -
I can open in cs but then how do I convert them to a vector file for corel 10?
thank you again for your help -
can you not import into corel?
here the are as cdr v10 -
save as an ai to an earlier version or save as a pdf should work
got a better biltein from brands, just for you
the thing about converting from my cs to an earlier illustrator is that it does not give me that option. its all eps or the same version option.
unless I am totally missing something -
You are a true honnie bunnie.
xBunnies have a lot of fun, because there are a lot of them,
why are there a lot of them? because they have a lot of fun.
Boom Boom,Peter
Cheryl,
When saving, at the bottom of the "save" dialogue box, choose the "Adobe Illustrator Document" option. Obviously.
Then comes up a second dialogue box headed "Illustrator Options". At the top of that there should be a drop down menu offering the choice to save in various formats, as far back as Illustrator 3.
You get the same options when saving as an Illustrator eps.
That’s how it works on a Mac anyway, and I can’t see a PC being any different.
