Activity Feed › Forums › Sign Making Discussions › General Sign Topics › Fidge Magnets
Fidge Magnets
Posted by Jamie Kimp on March 14, 2009 at 6:48 pmDon’t know if this post is in the right area but anyway. I have tried to stick my business cards to some magnetic material but I can’t find any glue that works.
Has anyone got any ideas?
Shane Drew replied 15 years, 1 month ago 6 Members · 7 Replies -
double sided tape ??? never tried but it may work
Thanks I had a roll of 3m roll glue. That worked perfectly. Bit expensive though
If you have access to sublimation equipment you could try thesehttp://www.hometogifts.co.uk/magmates.htm
The best ones for doing this are the clear 2 part acrylic fridge magnets that enable you to put your business card inside.
They are on fleebay for about 40p each – qty’s of 20.
Cheers John
I buy printable magnetic and do my own business cards as fridge magnets, but I can buy pre scored rectangles on an A3 Mag sheet with doublesided tape on one side from my suppliers here, I’d imagine they would be available over there too….
You get 100 to a sheet. Costs me about $A3 each sheet.
you can buy solvent printable magnet on a roll from grafityp.co.uk and also anchor magnets. just print directly to the magnet what you need as an when needed and cut with a Stanley knife.
quote Robert Lambie:just print directly to the magnet what you need as an when needed and cut with a Stanley knife.
The print and cut machines will score it beautifully and then they just peel apart.
