Home Forums Sign Making Discussions General Sign Topics Facing a grave situation
  • Facing a grave situation
    Posted by brian the brush on 26 July 2002 at 14:51
    Hi Gray, the preparation is important, make sure that any loose gold and masonary are rubbed away with some fine emery paper. The only other problem is not to let the gold size collect in the bottom of the inverted carved letters, as the size will dry slower because it is thicker where it has collected and the gold leaf will not adhere correctly. I always take a dust sheet and put it over the work while the size goes off, to avoid insect and dust sticking to it. Enjoy the experience, Brian.
    Deleted User replied 23 years, 5 months ago 4 Members · 5 Replies
    26 July 2002 at 15:29
    applying leaf outdoors must be a nightmare is it not?
    wind must be a big problem… & no mike not that kind of wind 😉
  • Deleted User
    Deleted User
    26 July 2002 at 17:33
    Hey Grey, I painted a tombstone with black one shot, maybe ya can use gold one shot if they make it? werked good 😆 Steve
  • Steve Broughton
    27 July 2002 at 07:44
    Gray i have a book called “Signwork-A craftsmans manual” by Bill Stewart
    this is what it says in the gilding chapter:-
    Plaster, Concrete and Stone
    The surface must be dry and clean. Because they are absorbent they must be sealed with an alkali resisting primer.
    Thats it, best I can do mate
  • brian the brush
    27 July 2002 at 13:21
    If the stone has been gided before there should be no need to seal the surface and you should be able to gild over the existing gold. I would use a fast gold size ( one and a half hour tack ) and if the weather is HOT, which I always think it must be in you neck of the woods!! , I would keep checking the size which is likely to go off very quickly.
  • Deleted User
    Deleted User
    28 July 2002 at 06:02
    Gray When we’ve done gold work we make sure the surface is clean then we painted with one shot red (let it Dry) then apply the gold leaf over the paint the red base color enhances the gold makes it mor vibraint? hope this helps!
    oreo 8)
