fabricated signage: closed loop
job that i completed this week, the building as just been built & the cladding can only support a hanging weight of 5 kilos per span. So a aluminum frame had to be fabricated hence the vertical uprights, this was then mounted by drilling blind through the insulated cladding. Tapping 10mm threads & fitting the frame using bolts & ferrels. The trays are composite with SMPs returns trim as weight was still an issue even with the upright supports. Text is 5mm acrylic on stand offs supplied by Fabricut, everything was fabricated in house except the letteringKev
