Home Forums Software Discussions Signlab Software Exporting vehicle library from Signlab to illustrator
  • Exporting vehicle library from Signlab to illustrator
    Posted by Daniel Evans on 4 July 2016 at 07:52
    Hey guys
    I got an a old version of signlab but I’m use to illustrator and can’t really get on with it at the moment, I’m still learning it but when I’m in a rush, I go back to illustrator.
    In signlab I use full scale vehicle library images but illustrator can’t handle them, so how do i divide the file by 2000% so I can open it in illustrator, edit and cut with my graphtec plugin?
    Frank Droog replied 9 years, 5 months ago 5 Members · 9 Replies
  • 9 Replies
    4 July 2016 at 08:07
    Check there isn’t another set of files you can use. Most libraries contain files at actual size as well as at 20% to allow illustrator users to open them. (i.e .ai files instead of .eps)
  • Ewan Chrystal
    4 July 2016 at 10:49
    What library are you using. Impact give you AI files that open fine at 20%
  • Daniel Evans
    4 July 2016 at 11:41
    Thanks for replying.
    I’ve already designed the vehicle to full scale in signlab, I can open up a scaled down version in illustrator and reduce the graphics manually to fit it but surely there must be a way of reducing a signlab file by 2000% so I can save it and import it to illustrator? Well I hoped there was lol.
  • Ewan Chrystal
    4 July 2016 at 15:47
    Saw this on another site, might be worth trying.
    This is very simple to do:
    Open the Transform palette
    Lock the width and height
    In the W: input add "/10" (after the current value in the box in mm/inches/etc).
    This will divide the value by 10 and will therefore downscale everything to 10% of its original size.
  • Daniel Evans
    5 July 2016 at 09:31
    Thanks Ewan
    I’ll give that a go and let you know how I get on.
  • Daniel Evans
    5 July 2016 at 09:32
    Just re-reading this, do you mean in illustrator? I need to do it in signlab as illustrator won’t even open the file as it falls off the document.
    Thanks again.
    5 July 2016 at 09:55
    I’ve never used signlab but there must be a resize tool, even my old copy of Inspire had an option to resize either by percentage or by typing in a value, have you checked all the drop down options looking for either a scale or resize option
  • Ewan Chrystal
    5 July 2016 at 10:22
    Hi Daniel, I meant have a look in Signlab to see if you can do it this way
  • Frank Droog
    5 July 2016 at 13:34
    Select everything.
    Click on Layout/Size Move/Size.
    Make sure the lock is locked for proportional scaling
    Enter your percent scale down or use the up down arrow keys.
