Home Forums Software Discussions General Software Topics export/import issues with text
  • export/import issues with text
    Posted by Ryan Fairweather on 12 December 2006 at 09:47
    When i export a file with text, close down and then import that file to work on or print, all the text has been messed up.
    Smoothness of the curves etc have gone and its become very ‘nodey’ and jagged!
    Any clues anyone? Probably something simple?
    Ryan
    Stephen Morriss replied 19 years ago 6 Members · 7 Replies
  • 7 Replies
  • David Rogers
    12 December 2006 at 10:10
    What software are you working with?
  • Ryan Fairweather
    12 December 2006 at 10:17
    Corel X3
    12 December 2006 at 11:15
    If you import as straight eps, then you may have this problem.
    If you import as prn, ps, eps selection it should be better
    12 December 2006 at 11:25
    yes,, the corelx3 export filters are not as good as they used to be in 11… had similar issues with Copy/paste – DXF and AI formats. Say you have very small text and exported, then imported and becomes all wobbly.
    12 December 2006 at 17:31
    Dave I’m not seeing problems with eps this end, have you an example you can send me?
    Alan D
    13 December 2006 at 12:26
    quote Alan Drury:
    Alan D
    must confess, I don’t have any problems either Dave.
  • Stephen Morriss
    13 December 2006 at 12:59
    I use an older version of Corel and usually I just convert text to curves to cure this, doesn’t help if you need to edit afterwards though.
