Excelam 1400RS Cold Laminator
This is an 1400mm wide laminator, ideal for laminating 1370mm wide digital prints. Can also be used for mounting onto substrates.
A recent problem has arisen whereby the chrome wheel you turn to increase the tension doesn’t always provide enough tension, so that needs sorted. Apart from that which is no doubt a straightforward fix, everything works as it should including electric backing paper take up reel.
Open to sensible offers – I believe these machines new are 3.5k so grab a bargain
Located in Aberdeen, machine comes off stand and can be taken away in an estate car or delivered on a pallet at cost.
Call Jamie on 01224 588855
