Home Forums Software Discussions Signlab Software EPS files in Signlab
  • EPS files in Signlab
    Posted by Shaun Harris on 14 November 2008 at 09:07
    I am currently running 6.1 colour master and cannot open / imprt eps files is it because they are newer versions?
    I have discussed upgrading to signlab 8 and have been sent a demo by Richard at Signmaster. I know that version 8 will open eps files and pdf files but as I only have an edge 1 for printing are there any other benefits?
    Peter Dee replied 17 years, 1 month ago 4 Members · 5 Replies
  • J E Kempster
    14 November 2008 at 09:21
    I had the same trouble I found this answer on the boards some where
    this may work for you. Open them up in AI, export them in AI legacy another box will come down save them in Illustrator 3. Then import them into Signlab. It works for me. Good luck
  • Peter Dee
    14 November 2008 at 09:36
    Open in any version of Illustrator, select "save as" where you can give it a new name or overwrite the original, next option will give you a drop down list to select which version you want to save it in. Select version 8 and you should be OK.
    I have to do this for engraving files I send off as they still use older software.
  • Shaun Harris
    14 November 2008 at 10:05
    Thank you Gents
    that worked and will help me in the future.
    I know this is a signlab part of the forum but can you shed any light on this
    If I choose to open a file with Illustrator, Ai opens then says it cannot complete task and shuts down. If I open Ai then open the file it is fine.
  • John Singh
    14 November 2008 at 10:33
    It seems more and more designers are using the latest adobe illustrator (CS) and it seems that the older versions of Signlab have problems with opening
    Before I got Signlab 7.1 I asked the designers to save the eps to an earlier version such as 7 or earlier and convert everything to outline
    Signlab 7.1 is fantastic as it allows you to import pdf’s as vectors
    Worth its weight in gold when I consider the time spent mucking around with trying to open files
  • Peter Dee
    Don’t know.
    Have you got 2 versions of Illy on your system?
    Perhaps a file is not the correct version for your Illustrator and the program needs to be open first in order to convert it on opening.
