Activity Feed › Forums › Printing Discussions › Printer Ink › Eco Sol vs Ultra Max cleaning carts
Posted by Barry Williams on November 26, 2009 at 11:45 amGood morning all–
does anybody out there have any opinion on the use of Eco solvent cleaning carts in a Mutoh 38 currently using the Ultra type ink?
Will they safely flush the machine or are they likely to cause problems?
I have 3 eco cleaning carts and 1 ultra cleaning cart. Is the black K line to
be flushed with a dedicated K marked cart?
BarryBarry Williams replied 14 years, 5 months ago 3 Members · 6 Replies -
Hi Barry. Roland Eco sol Max and Mutoh Ultra are made by the same company. I have in the past mixed both inks in an Oce CS9160 which is a re branded Mutoh valuejet 1614. Both inks are made by TOYO in Japan.
If the cleaning carts are from Roland there shouldn’t be a problem.Cheers
Andre
quote Andre Woodcock:Hi Barry. Roland Eco sol Max and Mutoh Ultra are made by the same company. I have in the past mixed both inks in an Oce CS9160 which is a re branded Mutoh valuejet 1614. Both inks are made by TOYO in Japan.
Andre
Andre
thank you for your reply.
The cleaning carts that are to hand are all made by MUTOH. I have one "ultra" cart and the remainder are the "eco sol" cleaning type. My worry is if I use these different carts in a cleaning operation will it cause problems?
Is a separately marked cart required for the K black ? My consumables supplier is of the opinion that they should not be mixed—(well he would— new carts are approx €70-) even though when I changed the printer over to the Ultra inks last year, there was no problem in using out the eco sol inks alongside the Ultras—-allowing a less costly changeover and no partly used carts lying around.
Barry -
Barry
ecosol & Ecosol max/ultra inks are different you may find that the ecosol cleaner is not strong enough to clean the ultra inks. At a push you may find the the ink congels causing more problems for you. When i had my Rocky originally converted Art Systems flushed my machine first before fitting the ultra carts.Kev
quote Kevin Flowers:Barry
Kev,
many thanks for the advice. I will invest in a set of the correct carts.As a previous owner of a Rocky–did you ever experience problems with the printer stopping printing at approx 70% into a graphic? This one does it on occasions.
Thank you again for taking the trouble to answer the above—
Barry -
Barry
had it happened once it was communication problem with flexi, running a Roland Soljet now so it was a long time agoKev
[size=12]Kev
many thanks for your comments.
I think that I may deal with the Flexi problem by re-launching the program between jobs,this can often solve program-related glitches.
Regards,
Barry
