Home Forums Sign Making Discussions Vinyl Dust/dirt speckles under vinyl
  • Dust/dirt speckles under vinyl
    Posted by Daniel Evans on 9 April 2012 at 10:12
    Hey guys
    I have a question regarding dust particles or dirt under the vinyl. It’s one of those things that really bug me and I always seem to get them.
    I recently put some vinyl on skybond, printed images went on lovely, in certain light you can see speckles in the vinyl. I’m using 751 I clean with isopropyl before layering but I always seem to get it, any ideas what I’m doing wrong?
    Martin Pearson replied 13 years, 7 months ago 4 Members · 5 Replies
  • Neil Davey
    9 April 2012 at 11:06
    Whenever possible I try and lay vinyl or prints onto board in a near vertical position. We have a 16′ long easel on one wall so this helps. Also get some Tak rags, body shops use them, to wipe down the surface just before application.
    9 April 2012 at 12:20
    Tak rags will help as Neil suggested, might be worth looking at the area you use to apply vinyl as well to see if there is anyway you can cut down on dust particles. What sort of heating you use will make a difference, anything that blows warm air won’t help as it will carry airborne dust particles. Clothing you wear can make a difference as well. You really need a clean room environment to apply vinyl but unfortunately that’s an extremely expensive way of doing it :lol1: :lol1:
  • Daniel Evans
    9 April 2012 at 15:48
    Thanks guys, unfortunately I do everything in one room so it’s very hard to keep it spotless, heating is just standard radiators but I’ll give those tak rags ago to see if that will improve things, I might also try doing more things upright as Neil suggested.
    9 April 2012 at 18:41
    get rid of the carpet!
    9 April 2012 at 21:39
    Like Dave says if you have a carpet in the room get rid of it & put in something like linoleum that’s easy to keep clean and doesn’t harbour dust like carpet does.
    Do you need to do everything in the one room?? Now the better weather is on the way could you do some of the messy jobs either outside or in a garage?
    Try & remove any protective coverings from media slowly to help prevent the build up of static & buy yourself something like a lab coat which will spread less dust.
