Home Forums Sign Making Discussions Vinyl Double side clear vinyl
  • Double side clear vinyl
    Posted by Simon Prior on 14 October 2013 at 22:27
    Hi all, has anyone come across or has a supplier for double side clear vinyl. I want to create some window graphics and would like to be able to reverse print on white then laminate in the normal way but using a double sided clear laminate so I am then able to stick to the inside of a window. I’m sure there must be a solution to this problem i have ( my printer unfortunately doesn’t print white ink!) Thanks in advance if you can help..
    John Hughes replied 12 years ago 6 Members · 8 Replies
  • 8 Replies
    14 October 2013 at 22:37
    It’s a clear laminate your looking for not a clear vinyl. I have one that is optically clear which is the sort of thing you are looking for but unfortunately I can’t remember where I got it but most of the print media suppliers will probably stock something.
    Or I believe people reverse print to normal clear vinyl & then back with white which would be a cheaper option
  • Simon Prior
    14 October 2013 at 22:45
    thanks Martin, I didn’t want to have to back it with white as some of the things I do I send through the mail so it’s not really acceptable (as far as I’m concerned) to have the end user fit the white back. Take your point though if I was fitting it myself then that would be the way to go. cheers
  • Jamie Wood
    15 October 2013 at 07:37
    The easiest way to do it is reverse print onto clear, and then use white vinyl as a laminate, so you are doing it the opposite way round to usual. We do it like this all
    the time, and they come out fine. This is what Martin meant. If you reverse print onto
    white, and back it up with double sided, the white part would still have it’s backing
    sheet on.
  • David Rogers
    15 October 2013 at 07:40
    Not aware of any double sided clear laminate / vinyl except for the type known as optically clear double sided sticky tape (£££)
    As already said, it’s the case of printing in reverse on clear & laminating that in white to make your print appear sticky on the printed side if you don’t have a printer capable of backing it off in white.
  • Simon Prior
    15 October 2013 at 09:24
    Thanks a lot David and Jamie for clarifying that, i get it now, brilliant. I knew there had to be a way. Thank you very much. All the best, Simon
  • John Hughes
    15 October 2013 at 17:19
    While on this subject…….saw a restaurant window last week where the vinyl was a metallic gold with a black print and applied to the inside. Any ideas on how that was done ?
    I couldn’t get inside to have a closer look.
  • Graeme Dingwall
    15 October 2013 at 20:32
    Was it not just the same as above but instead of backing with white it was backed with gold!
  • John Hughes
    15 October 2013 at 22:17
    Graeme….. you may be right there…. 🙂
