Home › Forums › Sign Making Discussions › Graphic Design Help › Dot Matrix??
Dot Matrix??
Posted by Nicholas Gormley on 23 May 2011 at 08:58Hi all, how do use create the dot matrix effect or whats the best way?? I’m stuck on how to do this any help would be great.
Nicholas
John Gregson replied 14 years, 7 months ago 9 Members · 10 Replies -
Not sure what you mean? can you explain a bit more?
that looks like a round dot halftone….
sort of thing photoshop can generate
Yep I’d use photoshop then impost into illustrator and use live trace. Use a high resolution or the trace in illustrator will be messy.
– create the shape/word/logo in illustrator (usually in black + white)
– copy and paste into photoshop
– Use layer style to add an outer glow
– Flatten image then use filter>pixelate>color halftone
– set all the screen angles the same (usually 45 degrees) to achieve a single colour halftoneAt this point you may need to play around with the screen radius or go back and edit the outer glow to achieve the desired effect
– flatten image and copy into illustrator then run live trace. Again you will have to play with the settings to achieve the best result.
Good luck,
Owen -
you can also do it in corel, certainly 12 onwards,
you don’t say what software you use.
in corel, click bitmaps > mode > black and white (1bit) and you can then chose a few effects options,
once you have your image you can mess about with fills, fades, etc. you may probably have to trace it if you want it as a cuttable vector though,
http://vectips.com/tutorials/creating-halftone-effects/
or rasterbator !!!
http://homokaasu.org/rasterbator/
is good and quick for creating vector dots😀
