Home › Forums › Printing Discussions › Mimaki Printers › does anyone know what error code 30 is on the jv3 please?
Posted by John Childs on 2 November 2008 at 11:51I can’t lay my hands on my manual at the moment, so does anyone know what error code 30 is?
Bill McMurtry replied 17 years, 2 months ago 5 Members · 7 Replies -
No need to abort the mission John – mission control says ignore the error code and go for lunar landing š
an error occurs on the iinterface between the I/F board and the control board
(corrective measure) Perform a proper operation!
that’s what it says John?
a post taken from mimaki user group
my question is what where you doing last to the printer?
quote :We had an Error 30 in our JV3 160 SP and the m/c has been down
for nearly 6 months, finally a tech came and loaded the latest firmware
and the printer is running again apart from the loss of heads and income
but this is another story.It sound like you need to input head ID’s and check all the parameter
setting,
probably a job for a tech, error 30 can mean anything to do with heads & ink
etc.quote :Thanks, I got it straightened out upgraded the firmware to 7.1 and
now it recognizes the SS2 inks and got rid of the error 30. Now I
have a new problem the close cover warning keeps coming on and if I
press on the area right above the switch it will have but
as soon as I stop pressing it says close cover, as if the front was
open. is there a way to wire around the switch? noticed there is a red
and black wire going to the switch. btw locacted in louisville.thanks.
— wrote:
> Sounds like the parameters have been altered to accept the third
> party inks. I would try and get the original parameters from
Mimaki
> (email them with your serial # and tell them you are trying to
> reverse a third party ink installation) Upgrade your firmware once
> your original parameters have been installed. Keep in mind that
all
> of the service alignments will need to be performed for any
changes
> the printer has experienced since new..
> I am an independent Mimaki tech working out of the northeast.
Where
> are you located?
quote Dave Rowland:my question is what where you doing last to the printer?
Nothing much Dave.
It was printing fine. Switched it off and moved it five miles (carefully) and switched on again. Error 30. š
Arew you using the same computer an firewire card John?
Peter -
quote Peter Normington:Arew you using the same computer an firewire card John?
Surely am Peter.
Absolutely everything is the same. š
John, sounds like something has moved in the 5 mile shift š
From http://www.sawgrassink.com/v.php?pg=203#error30 …
quote :Iām getting an error 30, what does that mean?An error 30 is a general operation error that normally points out something simple that might have been overlooked. This includes trying to do alignments while the print head is too high, or trying to detect the media while a cover is open. Always check your sensors when this error comes up, normally closing a cover or lowering the media lever will remedy this.
