Home Forums Software Discussions Corel Software does anyone know how toplay with compression settings?
  • does anyone know how toplay with compression settings?
    Posted by Dave Bruce on 1 August 2006 at 12:21
    Anyone know how I can play with the compression settings in Corel 11 as I need to send a file zipped, but winzip doesn’t compress any more than Corel 11 default settings.
    Any advice appreciated.
    Tim Painter replied 19 years, 5 months ago 3 Members · 4 Replies
    1 August 2006 at 12:52
    That’s because the cdr format is already about as small as it gets, you can try pdf but I think its unlikely it will get much smaller.
    If you are using lenses/fountain fill and that sort of thing this will increase file size, assuming you are not using spot colours for these convert them to a bitmap this sometimes helps.
    Alan D
  • Dave Bruce
    1 August 2006 at 12:57
    Thanks Alan, I eventually found it, turned off compression then winzipped it, you are right came out the same size as Corel.
    What sort of photo resolution do you guys use for flyers?
    1 August 2006 at 14:58
    For litho 300dpi finished size – for digital it depends on where it is viewed I normally do it about 200dpi. Rodney has posted on this topic if you can find some of his back posts.
    Alan D
  • Tim Painter
    1 August 2006 at 15:03
    300 dpi. At a 1:1 scale.
    Why not PDF it with bleeds etc if there are any. Make sure you output CMYK and embed any fonts.
    Tim.
