Home Forums Software Discussions Signlab Software Does anyone have solution of the problem of .plt files?
  • Does anyone have solution of the problem of .plt files?
    Posted by Maureen Ellis on 16 March 2004 at 14:15
    Does anyone have a solution ot the problem of .plt files losing all their colour infomation when imported to signlab6 from Spandex (Graphics Advantage)?
    Still with imported .plt files, is their an easier or quicker way of joining all the paths back together with the make path command in signlab – it’s very time consuming!
    Any suggestion welcomed.
    Frank Droog replied 21 years, 6 months ago 6 Members · 8 Replies
  • 8 Replies
  • Darryl Seager
    17 March 2004 at 19:53
    Don’t know about signlab etc, but i have the problem the other way round!
    If i do something in Flexi, i export it as an AI / EPS file then re-open in Omega(spandex) Perhaps you could try something similar??
    Darryl
    18 March 2004 at 08:40
    Can Omega not export as EPS or AI?
    Alan
  • Henry Barker
    18 March 2004 at 15:02
    I think I noticed it was harder in E6 to import Omega files, I now have E6 rev 1 build 13 and it seems to work, but with an extra set of dotted lines?
    Omega can export most it has I believe the same import export filter that Corel uses, and that in turn should be similar to Signlab?
    There used to be problems exporting vinyl eps and ai files from Omega, centres of letters were filled but if you give the job Edge colours it seems to fix this, or save the job as a 6.2 GA file and export using the old GA import export filter.
  • RayW
    24 March 2004 at 12:34
    Are we talking about gerber PLT files or exported (HPGL) PLT files? My understanding is that Signlab e6.1 will import most gerber PLT files. If this is not the case please contact me attaching the offending files and I will see what can be done.
    Ray
  • Maureen Ellis
    6 April 2004 at 16:14
    Hello Ray – they are plt files which we import – we seem to have a number of problems- they come across without showing the colours – perhaps we are not using the correct procedure ? editing is also very difficult . How can we send you a file?
  • RayW
    7 April 2004 at 08:51
    hi, e-mail me attaching the files. (rayw@cadlink.plus.com).
    Ray
  • Maureen Ellis
    8 April 2004 at 12:46
    Hello Ray thanks for the help- makes a lot of difference !
  • Frank Droog
    12 May 2004 at 19:42
    For your info.
    The original import filter in SL 5.1/3 was written based on GA6.0 that could only cut vinyl. It didnt have Edge support. In that filter , absolutly every vector it saw, was imported as cut data and its color was the vinyl color of the object. In short, print only data was also imported as cut data and all info about foils abandoned.
    The import filter in Sl 61 and 7 has been massivly redone.
    We try to match the Print Only/ Cut Only/ Print N Cut of Ga/Omega
    So, Vinyl objects (by default)(but can be overridden) come in once as a Signlab Nonprinting vinyl object and then again as a cut object which displays as a dashed line.
    So, vinyl objects with foil should print and display properly,
    Vinyl only objetcs dont print (no foil) but do display in thier correct vinyl color. and (by default) vinyl objects will cut also.
    frank at cadlink
    The latest filter allows you to Disable/enable the bringing in of vinyl objects as cuttable objects.
    Dont forget, some people only/mainly print to the edge, some people only cut and dont even have an edge. They design in vinyl and send to the cutter so they need the dual import of vinyl as the dashed line cut data.
    Hope this clears up some confusion.
