Home › Forums › Vinyl Cutter Discussions › PCUT Vinyl Cutters › does anyone have experience of setting a pcut 630 please?
Posted by anthony lee on 16 February 2008 at 16:35hi guys,
i’m about to go insane, ive had my pcut 630 about a month and a half, and its just sat on my desk. ive tried every possible way to get it working with wndows vista from drivers to shrter usb cables!!ive even gone to length of buying a laptop with xp on it having hope it would work, i got my laptop today and still after hours of trial all i get is error.
does any1 have experience of setting a pcut 630 with either a vista or xp>
im willing to pay money for whomever can help!
sorry mods pls remove if this is not allowed, im just pretty desperate to get it working
thanks
ant
anthony lee replied 17 years, 10 months ago 5 Members · 9 Replies -
Could you tell me a bit more..? Not used Vista before so not sure about configuring that. Try the laptop with XP first.
What software are you running on the laptop…??
What settings have you got on the usb port – serial converter?John.
at the mo
im using signblazer demo but this should be fully functional with some screens at the start up asking me to registermy settings are from the other thread as follows
Bits Per Second: 9600
Parity: None
Stop Bits: 1
Flow Control: HardwareClick Advanced, set as follows:
Com Port Number: Com2
USB Transfer Sizes: Receive = 4096, Transmit = 4096
Latency Times = 1MS
Minimum Read/Write Time Out = 0MS
Serial Enumerator = Ticked
Serial Printer = Ticked
Cancel If Power On = Ticked
Event On Surprise Removal = Ticked
Set RTS On Close = TickedClick OK and OK again.
Close Device Manager
4. Open what ever cutting software you wish to use and set it up as follows:
Cutter = Creation PCut CT630
Serial Port/Com Port = Com2
Com Port Speed = 9600
Flow Control = Hardware5. Check the port speed on the cutter is set to 9600.
now ive got an email today from the previous owner who had only limited knowledge of the setup but he told me to go into control panel and printers, then add printer -then some how add the pcut (but everytime i try add the printer from the cd that came with the cutter, it says there are no setup files?) anyways he said after doing this set it as the default printer
hope this helps
really and honestly appreciate your replies
thanks
Your settings appear to be the same as mine. Not sure about the software setup as I’m not using signblazer. I did get signblazer with the pcut but having already bought WinPC sign I didn’t actually use it.
Sorry I can’t offer any assistance other than to suggest trying some different software.
John.
i dont know for sure but most demo software will not cut. have you spoken to SB.
Anthony,
I run a similar setup to yourself. We run two Pcut 630’s (no problems) with Signblazer software on the Vista operating system. We haven’t actually had a problem with the software or cutters and we’ve been using them for a bit over a year.
I use Signblazer. My PC crashed and destroyed itself last week. Luckily I had a back-up of all files and designs. I had to reinstall the signblazer and when it was in Demo mode it let me cut ok. But this could have been due to being installed in the system before?
Maybe you could check on the SB forums themselves. I have spoken with Jerry from on there on a number of occassions with one thing or another. He has been really really helpful, infact I’ve found him a lot more helpful than Signwizard.
I’m not at the office right now to check our settings. I’ll be there this afternoon though so will check our settings and let you know what are settings are.
All the Best
Jonny -
hi there, thanks for the replies
ive actually emailed signwizard the supplier several times, i think to the point where they dont even email me back 🙄
as for sb forum, ive been there, i did everything they asked.. the last idea was to try a shorter usb cable in which i did and had no luck… after that they didnt know what to suggest.
can anyone confirm that in contropl panel > printers > i should have a pcut 630 displaying as one of my printers? cause at the moment there is nothing in my printers folder?
cheers jonny they will be massively be helpful!
ant
il give that a shot, dont really think they will provide me with much support especially that their offices are in china,, il try anyhow
thanks
