Home Forums Sign Making Discussions Vinyl do i have to use wrap vinyl to go over rivets?
  • do i have to use wrap vinyl to go over rivets?
    Posted by Warren Beard on 16 January 2008 at 19:37
    Hi All
    I was wondering if it is necessary to use wrap vinyl for a truck with rivets (lots of rivets) It is a box truck so no recesses.
    Do I have to use wrap vinyl? what are my alternatives?
    Warren
    Nancy Wannous replied 17 years, 10 months ago 5 Members · 10 Replies
  • 10 Replies
    16 January 2008 at 19:45
    No you don’t need to use a wrap vinyl Warren, any good cast vinyl such as 751C will do the job.
    Don’t forget to add extra time to fitting to cover the extra work involved.
  • Warren Beard
    16 January 2008 at 19:47
    Thanks Martin but I forgot to mention it is digital print 😳
    Sorry and thanks anyway
    Warren
    16 January 2008 at 19:51
    Warren, doesn’t matter you can print onto cast as easy as any other vinyl. It might work out a bit cheaper printed onto cast as well.
  • Warren Beard
    16 January 2008 at 20:02
    Hi Martin
    Excuse my ignorance, I thought you had to use proper digital media and not normal 751C, or am I being silly and you are talking about a digital media cast material. I have one quote on calendered wrap vinyl but was wondering if there was a cheaper alternative as it is just for rivets and not recesses.
    Warren
    16 January 2008 at 20:11
    Warren, it does need to be digital media, normal vinyl can be printed on, but then the problem is cleanliness, quite often normal vinyl has surface contamination, so its not advisable.
    I would use a cast digital (does not have to be specifically a wrap vinyl though,)
  • Warren Beard
    16 January 2008 at 20:44
    Thanks Peter
    I just need to find somebody who can print and supply to me then 😕
    Warren
  • Peter Munday
    16 January 2008 at 23:25
    Warren this might make life easier.
    http://www.rollepro.com/
    16 January 2008 at 23:54
    Peter, Have you used one?
    I know Rob has had one on demo, and was going to evaluate it, I see they are being sold in the UK now, so I would be interested to know if they are as good as the look, or would they need some practice to use?
  • Warren Beard
    17 January 2008 at 08:26
    quote Peter Munday:
    Believe it or not I was actually considering it :lol1: I’m sure by the time I’m finished I will be a "roller pro" 😉 :lol1:
  • Nancy Wannous
    17 January 2008 at 22:24
    id use MPI 1900 with dol 1030 5 yrs outdoor and UV stabled
