Home Forums Software Discussions Flexi Sign Software do i have a driver issue or compatibility problems?
  • do i have a driver issue or compatibility problems?
    Posted by ridgewoodsignal on 20 June 2006 at 16:40
    I sent a file to my Graphtec FC7000-75 to be cut from Flexisign 7.6 but when the plotter cuts it cuts these small letters/numbers vertically on the edge of the vinyl. I then exported the file to Illustrator and it cut it out fine.
    Could this be a driver issue or compatibility problems with Flexisign and the Plotter?
    Adam McGuire replied 19 years, 5 months ago 3 Members · 7 Replies
  • 7 Replies
  • ridgewoodsignal
    21 June 2006 at 12:28
    I reinstalled the drivers and even downloaded the new drivers from the Graphtec website but the plotter still cuts like a code of letters and numbers along the edge of the vinyl. Does anyone else use a setup similar to mine with a graphtec plotter conected to a USB port under Windows XP?
    The plotter will cut in other programs so i know the plotter works fine. Any help will be appreciated.
    Thanks,
    Jim
  • jeffus – Graphtec
    21 June 2006 at 12:55
    Sounds like your Graphtec is set to GPGL command language,which is ok for the Graphtec windows driver and the Illustrator plugin, Flexisign needs it to be in HPGL,
    go into the menu on the Graphtec and look for command , go into there and change to HPGL, press emter to store the changes,
    Jeff
  • ridgewoodsignal
    21 June 2006 at 13:00
    Thanks for the advice. I went into the menu and changed the language to HP-GL but when i selected it the graphtec forze. Should i wait or should i turn it off then turn it back on?
  • ridgewoodsignal
    21 June 2006 at 13:08
    Nevermind i got thanks for all the help.
    Jim
  • jeffus – Graphtec
    21 June 2006 at 13:16
    Hi Another thing to watch out for the FC7000 Graphtec is set to be controlled by the software, and flexi sign changes the offset to pen and a fast speed,
    again in the menu under background settings you can change it from program to manual.
    Jeff
  • ridgewoodsignal
    21 June 2006 at 13:19
    Thanks for all the help i don’t think i would have ever figured that out.
    Jim
  • Adam McGuire
    21 June 2006 at 14:09
    That’s strage, because my Roland has done that before! With Flexi!. It seemes to be after I started using SignLab. I had to delete the Roland, and re-install it again. It does it every now and then still. Might rebuild the PC and see if that helps.
    Adam
