Home Forums Software Discussions General Software Topics disapearing fonts ?!
  • disapearing fonts ?!
    Posted by Alan Wharton on 6 January 2007 at 19:22
    i did some work at home using ms publisher put it on a disc then at the unit today tried opening using publisher and it came up saying various fonts missing and replace them with x font. i opened the file went to fonts and the only fonts in there were DEVICE FONT 15/17 and 17 !!! checked everything i could think of including opening new document starting a fresh same thing strange, went to word to do it there only to find exactly the same fault so i thought ok i will go use corel word and thats the same no fonts but these 3 DEVICE FONTS my vmp is fine but just about everything else has gone down the pan any ideas what can cause font to do a runner from umpteen apps at the same time?
    Alan Wharton replied 18 years, 11 months ago 5 Members · 6 Replies
  • Nick Minall
    6 January 2007 at 19:26
    Are all the fonts in windows font folder?
    6 January 2007 at 19:33
    check for another Fonts folder in c:\windows or whatever its called.
    might have moved it by accident and windows re-created a new one.
  • George Kern
    6 January 2007 at 19:35
    Alan, it sounds like something got corrupted in your windows font folder. In any case, in my past experiences with this happening the fonts are not lost forever, just misplaced on your system. Go to "Search" from your start menu, then "all files and folders" and in the 1st search field type the font extensions. e.g. .ttf, .fon, .otf etc.
    You could also check your system events log to see if anything caused this.
    1. Click Start, and then click Control Panel. Click Performance and Maintenance, then click Administrative Tools, and then double-click Computer Management. Or, open the MMC containing the Event Viewer snap-in.
    2. In the console tree, click Event Viewer.
    The Application, Security, and System logs are displayed in the Event Viewer window. You would be looking in the application and system sections to see if there was any corruption or conflicts.
  • Alan Wharton
    6 January 2007 at 22:04
    i disable all the jumk in xp george ie system logs/events etc as its never ever used, i think i only have 9 things actually running on windows xp i switch everything off, although i did do i search for fonts and there is nothing coming up in windows no folder font manager or anything iv just checked this pc at home and there is a font folder in windows so maybe ill copy it on disc and put it on my work pc monday. or il do what i normally do and thats format it AGAIN (hot)
  • Gordon Forbes
    7 January 2007 at 12:13
    Once you have so many fonts in the fonts folder it no longer updates.
    You have to get rid of some. Can’t remember how much but it is quite a few.
    Goop
  • Alan Wharton
    9 January 2007 at 16:51
    aha found the problem of the disapearing fonts and only DEVICE FONT in the drop down font list, because i had my vinyl cutter set as the DEFAULT PRINTER and there are no fonts to use in it thats why all my apps were showing device font only pfftttt, formatted my pc aswell because of this, and after a fresh install of everything i still had the same problem, note to self dont set vinyl cutter as default printer as it naffs up all your normal apps that use fonts, word/corel office/publisher etc etc.
