Home › Forums › Sign Making Discussions › Vinyl › digital print how much left on a roll
Posted by Bob Scullion on 13 September 2011 at 09:24Any tips on working out how much material is left on a roll other than having to unroll it all.
Using oracal 3164 if it makes any difference.
For arguments sake if I have 10mm of vinyl rolled on the core is it safe to say I have X amount left.
Don’t want to start printing an 8mtr length to find out I’m short.
Anyone got a formula the use maybe for stocktaking their material
Bob
Chris Wool replied 14 years, 1 month ago 10 Members · 15 Replies -
Hi Bob,
i did use the Roland tool for printing the remaining amount on a roll
but its a bit of a faffnow i just have a spread sheet and put a code on the inside of the core
Just thought there may be a rough guide someone used.
Some window film manufacturers have it printed on the release liner every 2 to 3 feet so you know how much you have left.
Might not be such a bad idea for the vinyl companies to do likewise on full 50 meter rolls on the backing paper..
Don’t want to unroll the media and get it contaminated.
ah this is always a issue
if ur not sure order the roll.
quote Dave Rowland:ah this is always a issue
Done so Dave, looks like I am going to be left with a few rolls with X amount on them over time.
When we get low on the roll, we normally put that roll to 1 side and use for short length jobs, such as 100 small decals. They get used sooner or later.
I have used this in the past with good results.
http://www.cutsmart.com/pages/length_on … lator.html
Al.
quote Robert T Walker:Hi Bob,
Robert, how do you use this – always remember hearing about it but never managed to find it!
Andy
Hi Andy
Its Sheet Remain
you set the full roll length then ‘PRINT MEMO’
when you come to take the media off the machine
‘PRINT MEMO again and it prints the remaining roll length
on the trailing edge of the media -
I never knew about this feature either. Useful information – thanks Robert 😀
As a very rough average there is 260mm per turn left on small amounts.
So count the turns and times by .26 gives you the meters remaining, there’s usually more left but it’s better that way 🙂Steve
quote Robert T Walker:Hi Andy
Its Sheet Remain
on the trailing edge of the mediaBeing blond (not grey for a change!!) is this in versaworks?? if so where am I not looking
Andy
It’s on the printer control panel itself Andy. Press the menu button then scroll through until you find it
you are not the only one andy, i only found it whilst looking for something else.
thanks robert
