There are a number of options when considering buying ACM
The cheaper hoarding board options are great for short term applications mainly flat panel work. Most of the sheets are 3mm thick as standard with varying skin thickness
All ACM will expand and contract so the correct fixing method will always need to be considered especially in south facing conditions.
3mm single sided hoarding tends to be single sided Matt white , mill reverse with either .12 or .15 skin. (You pay your price and takes your chance)
3mm double sided lite ACM .2 skin this is a great choice if your not folding. These sheets tend to be Matt one side and gloss the other in white and colours (depending on the quality of the core, some people can also fold this grade)
3mm double sided fabrication grade sheet double sided .3 skin Matt one side gloss the other in white / colours and special finishes
Then there’s a range of sheets specifically designed for the direct to print market, these sheets have been optimised to be printed directly too
