Home Forums Sign Making Discussions Neon, LED, Lighting Dibond tray support question
  • Dibond tray support question
    Posted by Gavin MacMillan on 17 December 2009 at 12:33
    what do people do to reduce the flex on the face of a large comp. aluminium sign tray, got a couple here at 1100high and am wondering about maybe gluing or taping some angle vertically on the rear to stop it flexing. is this worthwhile / required? Anyone have other options?
    Many thanks, G
    KeithdWhitson replied 15 years, 12 months ago 5 Members · 5 Replies
    17 December 2009 at 12:37
    is it lit?
  • Gavin MacMillan
    17 December 2009 at 12:51
    Nope, not lit or fret cut, standard tray, 80mm returns, 2800mm wide.
  • Colin Bland
    18 December 2009 at 12:32
    are you having a gloss face of matt face ?
    You will need to be more careful if gloss face at the angle would witness on the face – we sometimes use an offcut of alucobond say 150mm wide bond that into back of panel and then bond the angle to it spreads the load a little
    Colin
  • Gordon Jones
    18 December 2009 at 18:34
    quote Gavin MacMillan:
    Many thanks, G
    Gavin, I make a quick 2×2 wooden frame, fit that, then fit the tray to that, makes it very rigid
  • KeithdWhitson
    18 December 2009 at 18:39
    you could always vhb tape some ‘L’ angle to the rear although i’ve built many big dibond trays and never used anything to stop flex, no complaints or failures yet.
