Home Forums Printing Discussions Roland Printers Cutting with a VS-640i
  • Cutting with a VS-640i
    Posted by Daniel Evans on 29 October 2015 at 09:41
    Hi guys
    I need to just cut with my new roland printer, normally I would use my cutter but the extra width I have with the printer will help me so I’ve decided to use this instead.
    Is there not a plugin that I can use rather than use versa works?
    I’m wanting to cut Hexis HX20000 material.
    I have my design, I’ve setup a contour cut line, i’ve got the ants in versa works but I don’t know what pressure/force to do, what the offset should be, speed and I assume i’d only do 1 pass.
    Also I can’t see a way on how to setup up conditions like I would on the cutting master 3 software for my graphtec?
    Ideally I would like to save the cut settings for different materials so all I would need to do it sleet that setting and it will work depending on what condition the blade is in at the time.
    Daniel Evans replied 10 years, 2 months ago 2 Members · 2 Replies
  • James Boden
    29 October 2015 at 10:33
    Hi Daniel,
    I have a different roland machine but the settings I use everyday are:
    Cut pass : 1
    Speed : 30
    Pressure : 130 – 150
    Offset 0.250
    As your machines a different model I’d do a few test cuts at a much lower pressure until you find the right setting.
  • Daniel Evans
    29 October 2015 at 10:38
    Hi James
    Thank you very much.
    I’ll give that a go.
