Home Forums Software Discussions General Software Topics cutting probs with an image- help ?
  • cutting probs with an image- help ?
    Posted by onestopsigns on 24 April 2005 at 14:12
    a few times ive tried to cut different images
    today ive cut a dragon i downloaded from here
    ive now cut 3 times and 3 dif sizes
    aprox 40 cm long works fine
    65 and 90 cm long it misses the tail well half the tail and some of the details then scores a line through it from front claw through head
    now there cant be any thing wrong with the image as it cuts fine smaller
    so wat the heck and i doing wrong
    the same happened to a celtic footbal club logo still cant do that one over 8 inches
    any ideas appreciated
    onestopsigns replied 20 years, 7 months ago 3 Members · 7 Replies
  • 7 Replies
  • Jayne Marsh
    24 April 2005 at 14:17
    Sounds to me like your software is putting anything past a certain size into panels. Check what setting you have for your cutting software and alter the panel sizes. What software are you using?
  • onestopsigns
    24 April 2005 at 14:45
    artcut2002
    will have a look for panel settings
  • Jayne Marsh
    24 April 2005 at 14:47
    Also take a look at what material width you have got set up, this also affects wether your software will automatically put larger images into panels
  • onestopsigns
    24 April 2005 at 17:31
    IT IS IN PANNELS
    IT WOULD APEAR IF I CAN STRAIGHTEN THE IMAGE THEN I CAN MAKE IT FIT
    BUT ITS PROVEING A PAIN
    IVE ATTACHED THE IMAGE HOPEFULLY
    ITSA RED BACKGROUND AND WHITE DRAGON I WANT THE WHITE DRAGON NOT THE RED SQUARE
    BUT GOES FROM BOTTOM LEFT TO TOP RIGHT DIAGONALLY IF IT WENT STRAIGHT IT WOULDNT BE A PROBLEM LOOKING TO CUT THIS AT A SIZE OF 55CM HIGH BY 180 CM LONG
    CANT FIND THE ATTACH BIT LOL
    BUT HERES A LINK
    http://www.uksignboards.com/viewtopic.p … ght=dragon
    NOW ITS THE MIDDLE ONE I WANT AS THE BOTTOM 1 DOESNT HAVE AS MUCH DETAIL
    CAN ANY 1 HELP ME SORT THIS OUT PLEASE DOING MY HEAD IN LOL AND ITS PROB SOMET SIMPLE
    [/img]
    24 April 2005 at 20:19
    If you view it as an outline its not a good vector, I have sorted it, but cant post here so will put it in the swap forum
  • Jayne Marsh
    24 April 2005 at 20:24
    Im trying to understand your problem……..is it that you dont want the red square at all? In which case just ungroup the image and delete the red square leaving you with just the dragon, then size it as you want, if necessary rotate the image to fit your vinyl and away you go! Check the max width of your vinyl and make sure you can fit it on.
  • onestopsigns
    24 April 2005 at 20:53
    cheers peter and jill thanks played a bit more with you said last and think ive done it was trying all morning but was not manageing with ur help ive cracked it i think
    the reds gone the image is straight so the panels shouldnt be affected
    so should cut it out now cheers off to try it
