Home Forums Sign Making Discussions General Sign Topics Cutting Panatrim
  • Cutting Panatrim
    Posted by Sparky on 12 September 2002 at 10:04
    Hi peeps,
    What’s the best tool for cutting panatrim ??
    I have got a small chopsaw & it does do the job ok but worrying if the blade is going to “snag” the Alli is always a consideration 😕
    I can’t get an Alli cutting blade for the saw I have (190mm / 24mm centre) so am stuck with using the 24 tooth blade !
    Is it safe ?? Your opinions ??
    Spark
    Sparky replied 23 years, 3 months ago 3 Members · 6 Replies
  • Andrew Blackett
    12 September 2002 at 10:20
    we have a makita power mitre saw, with a metal cutting blade in, works perfect for cutting aluminium framing etc
    ANDY
  • Sparky
    12 September 2002 at 10:34
    Hi Andy,
    Has the saw got a toothed blade or a metal cutting disc
    Spark
  • Andrew Blackett
    12 September 2002 at 10:53
    toothed blade,
    according to the lad when he bought it, the fella in the shop said it had some special design that limited kick back
    ANDY
  • Sparky
    13 September 2002 at 14:57
    Thanx Andy
    15 September 2002 at 22:56
    Hi Sparky, I wouldn’t be cutting ally framing with a wood blade, you will probably get away with it for a while but you will soon knacker the blade and then it wont be any good for cutting at all. If you know any engineering firms they could probably make you a bush for a couple of quid if you can’t buy a 24mm bore blade. You really need a blade with negative rake for cutting ally If you can’t get a 190mm blade I know screwfix do a 185mm blade.
  • Sparky
    16 September 2002 at 12:39
    Martin,
    thanks m8, I just ordered a saw and alli blade from screwfix today, total of about £90 ….. not a lot of money to be safe is it !!
    Regards,
    Spark
