Home Forums Vinyl Cutter Discussions Graphtec Vinyl Cutters Cutting Master 2 not connecting to Graphtec FC7000-130
  • Cutting Master 2 not connecting to Graphtec FC7000-130
    Posted by Neil English on 10 July 2009 at 10:26
    Hello,
    Hopefully someone may be able to help?
    I am having problems with cutting using Cutting Master 2, Corel X3 and a Graphtec FC7000-130.
    Basically the cutting master 2 software isnt recognizing the cutter, when I try and get the poll size I get the error message "cutter is not responding to poll size" also when I go to cut the message "Cannot open port" comes up.
    I have downloaded the latest drivers and cutting master 2 latest version, I have repaired the Corel X3 install, reinstalled all software and driver, still no joy.
    I am using the USB connection, also using windows XP.
    I know it does work, as it was working before!
    Any help would be greatly appreciated.
    Thank you
    Neil 😀
    David-Foster- replied 16 years, 4 months ago 3 Members · 6 Replies
  • Mark Jahn
    10 July 2009 at 10:34
    Does the cutter show up within your printers in Control Panel Neil? And if so, when it’s turned on does it show as online?
    Sounds like a possible connection problem with the usb cable – can you cut using any other software – even the basic stuff that came with your Graphtec?
  • Neil English
    10 July 2009 at 10:36
    Hello, thanks for your quick reply,
    Yes the cutter does show up, and is online.
    I can cut using sign tools 3 with the usb.
  • Neil English
    14 July 2009 at 14:29
    Problem fixed!
    I was using Cutting Master 2 v 1.6 the latest version with Corel X3
    Decided to find v 1.5 and give that a try, and touch wood no more problems. 😀
  • David-Foster-
    14 July 2009 at 15:15
    What is the difference between cutting with Cutting Master and Sign Tools 3? I just thought if you are using Sign Tools no need for Cutting Master?
  • Neil English
    14 July 2009 at 16:06
    Sign Tools 3 will only cut a maximum length of 3.2m. Sometimes I need to cut longer lengths than that.
  • David-Foster-
    14 July 2009 at 17:45
    Aaahh, thanks Neil, good to know, even if I doubt I will be cutting longer than 3.2m 😮
