Home Forums Vinyl Cutter Discussions Summa Cutters Cutting Laminated Graphics
  • Cutting Laminated Graphics
    Posted by Brad.Kitchener on 11 February 2019 at 19:51
    Does anyone else have a problem cutting laminated graphics? I am using a brand new smart blade, only cut a few jobs with it and now it will not cut through. I am using 100mic vinyl and lam, the pressure was set at 120g and was cutting beautifully until today.
    Any ideas?
    Martin Oxenham replied 6 years, 10 months ago 9 Members · 10 Replies
  • 10 Replies
  • Chris Windebank
    11 February 2019 at 19:57
    as a rule of thumb, a new Smart blade on my versacamm will cut print and laminate at 90
    Without lam 50-55
    Has it hit a media clamp?
  • Pane Talev
    11 February 2019 at 20:14
    With a pretty old smart knife at the moment, my Summa cuts with 80g (M7, MD3/MD5) and 160g laminated MD3/MD5 with their recommended laminates.
  • Mark Piddington
    12 February 2019 at 00:09
    What condition is your cutting strip in Brad?
  • Brad.Kitchener
    12 February 2019 at 00:28
    quote Mark Piddington:
    Cutting strip is in perfect condition, no grooves at all. I just don’t understand, how it was cutting perfectly, then not!
  • Brad.Kitchener
    12 February 2019 at 00:29
    quote Chris Windebank:
    Without lam 50-55
    No, I am pretty sure it hasn’t.
    It’s a real head scratcher.
    12 February 2019 at 08:56
    How do you know it hasn’t hit a media clamp? This is the most likely explanation. Have a close look at the knife to ensure it hasn’t lost the tip.
    12 February 2019 at 11:12
    a loupe was the best thing i ever bought for checking blades and just looked so cheap now.
  • Andrew Weaver
    15 February 2019 at 23:41
    We had the same problem this week and having a closer look there was a small piece of vinyl stuck to the blade …!!
    Just have a close look Incase 🙂
  • Lee Reeves
    17 February 2019 at 11:23
    Could be glue build up on the blade try cleaning with some ipa it’s worked for us.
  • Martin Oxenham
    17 February 2019 at 19:05
    Is it a Roland machine ?. We had the same problem a while back and Harry at Mathias recommended not pushing the blade fully into the holder. Use a credit card as a thickness guide. Ours was hitting the media clamp, It’s a well known problem as the tip just skims the metal and takes the edge off.
