Home › Forums › Vinyl Cutter Discussions › General Cutter topics › Cutter not quite cutting the whole job
Posted by Phil hooner on 14 January 2007 at 21:02HI all ,this is my first post on here after reading the forum for a while.
I have bought myself a Creation Pcut 630 Via signwizard, and am using flexsign Pro 7.6.
My question is,when i am using the cutter it is running in its slowest speed but not quite cutting to the edges of letters, most letters will be ok, but some will not is this down to my software settings? if so does anyone know what it is i need to be altering?Thanks Phil
Phil hooner replied 18 years, 11 months ago 8 Members · 13 Replies -
do you mean its not clean in say a corner ??
i would say blade offset
the speed can be set from production manager and on the plotter although I’m not sure on setting for a p cut which has the most amount of posts re setting the thing up and getting it working -
I have never really got my Pcut to perfectly finish the letters especially with smaller letters where it is more noticable.
I cut most jobs with the speed set at 40 or 50 and the blade offset set at 0.27mm.
Russ
i cut at a speed of 500 even with text @10mm and its clean and weeds easy
i think these are a good start and value for money but for a busy shop the pcut it limited after reading so many set up problems -
yes rich
quote :for a p cut which has the most amount of posts re setting the thing up and getting it workingand its getting boring. like new members on number plates
possible page size mismatch in answer to the post.
i wouldnt mind playing with a pcut to see if they really are bad or not.
or just new finger troublechris
On flexi-sign there should be a button to get the page size from the cutter. If you have been cutting on 500 mm then put 610 in it still thinks you have 500mm in.
Thanks for the replys guys i will try some adjustments today, i think i will try using my PC over the laptop too.
Thanks Phil -
Hi all tried adjusting the page size with no benefits, i tried using artcut and that cut perfectly, but i dont like using that software , whenever i switch back to using the flexisign it cuts a scruffy job every time.
Phil
Have you tried contacting Scanvec about this problem? There have been quite a lot of these plotters sold so they may well already have an answer.
No i had’nt thought of emailing them direct i will do that and await their reply.
Thanks Phil -
I would definitely try the blade offset. Mine is set to 0.025, just check your packet which the blade came in.
Glen
Phil i couldn’t insert an image here, so i’ve started another post with the same title so you can see what you need to click. 😀
Hope this helps?
Glen -
blade offset for sure
I had the same problem with my pCut, changed it 2mm (i think) and now it completes all cuts smoothly.
Does the job for me. Although when I finally get my own workshop, I may end up getting a print & cut machine to run along side it.
Thanks For the replies i tried adjusting the blade offset but not by as much as 2mm, i will try more adjustment on my next use of the cutter.
thanks Phil
