• Cutter help
    Posted by Lorraine Buchan on 30 September 2003 at 09:16
    the last couple of days have been a night mare trying to cut easy cut transfer material. The corners of letters don’t seem to be cutting well at all making weedign readly teadious and painful. this is on rounded letters such as S and G but all so on E it’s worst on smaller letters for weeding but its also bad on bigger letter though you can hold them down so it’s easier to weed
    I’ve increased my force which helps but not much
    Any ideas please
    Lorraine Buchan replied 22 years, 1 month ago 3 Members · 5 Replies
  • Rodney Gold
    30 September 2003 at 09:51
    Have you checked you havent reset your blade offset?
    Have you changed blades to a sharper one ? Perhaps the tip of the blade isnt sticking out far enough out the holer? Have you tried slowing the cutting speed?
    Im open to correction here , but I think blades for cutting thicker harder stuff are a little different?
  • Lorraine Buchan
    30 September 2003 at 10:10
    nothing has changed settings wise, I’m not that clued up with plotters to be honest and this one i’m using i’ve used since i first started signmaking and i haven’t change a thing since the first day
  • Lorraine Buchan
    30 September 2003 at 10:12
    Vinyls seem to be fine still its just the transfer material that i’m having problems with
  • Kevin Flowers
    30 September 2003 at 14:00
    Lorriane
    what cutter and software are you using
    i use Easy Cut and when cutting small letters etc i slow the speed down settings for the summa are
    speed 150
    offset .48
    force 60-75
    using Edward Mathius blade can normally cut down to 7-8 mm letters in easy cut
    summa software also as the facility to increase overcut
    have you fitted another blade etc recently, if so
    did the problem start after that etc
    hope you solve the prob soon
    Kevin
  • Lorraine Buchan
    30 September 2003 at 14:57
    Hi Kev
    Thanks for your replies, nothing had change with the plotter.
    I’m using a summa cut D500 with flexisign.
    The problem has been sorted now, but i think it has a lot to do with the fact i have a really old blade in use and the cutting strip is fairly knackered.
    I have ordered some blades and a new cutting strip from Harry.
    To solve the problem in the meantime i have increased the over cut.
    Thanks for all the help
