• Cut path Help
    Posted by Paul Goodwin on 16 February 2005 at 16:13
    Hi all hopefully someone can help me with this one.
    This is my first printed vinyl job so i’m def a newbie on this one.
    I have a few images to put on a van, using Photoshop i have grabed the images from the photos i want to use and put a white boarder around them, the question is this, how do i put a cut path on the outside of the white boader for the guy who is doing the printing to cut in corel?
    does the cut path have to be done in corel or can it be made in ps and exported, he only knows how to use corel.
    Paul
    Tim Painter replied 20 years, 10 months ago 4 Members · 7 Replies
  • 7 Replies
  • Tim Painter
    16 February 2005 at 16:34
    you can create a clipping path in Photoshop and export as and ai file.
    Use the help file in PShop.
    Sorry I cant help more.
    Tim.
    16 February 2005 at 16:37
    you only have to put a hairline box in the right place he will posibly need to change it to how he has his softwear set
    just reread the post take no notice
  • Tim Painter
    16 February 2005 at 16:53
    The Paths to Illustrator command lets you export Photoshop paths as Adobe Illustrator files. This makes it easier to work with combined Photoshop and Illustrator artwork or to use Photoshop features on Illustrator artwork. For example, you may want to export a pen tool path and stroke it to use as a trap with a Photoshop clipping path you are printing in Illustrator. You can also use this feature to align Illustrator text or objects with Photoshop paths.
    To use the Paths to Illustrator command:
    1 Draw and save a path or convert an existing selection into a path.
    2 Choose File > Export > Paths to Illustrator.
    3 Choose a location for the exported path, and enter a filename.
    4 Click Save.
    From Adobe Help
  • Paul Goodwin
    16 February 2005 at 17:22
    Cheers guys
    I made a path and can import that into corel, but how do i link that with the image in corel?
    also i notice when i open the .psd image in corel it doesn’t bring accross the white outline i have around it. ( made with outer glow )
    16 February 2005 at 20:36
    Use the path as a powerclip shape. Powerclip the image into that and you can add an outline to that
    16 February 2005 at 20:38
    soory mort i din not think you used corel
    import the image in to corel best as a tiff size the image to its correct size then draw a path leave it as a hairline over the top of the image where you want the print to be cut at the correct size save as a corel file give it to him.
  • Tim Painter
    17 February 2005 at 08:51
    sound like you enjoy hard work Chris.
    Draw a path by hand when a few clicks does it for you?
    Tim.
