Home Forums Sign Making Discussions General Sign Topics Cut out single solid (flat) letters?
  • Cut out single solid (flat) letters?
    Posted by J. Hulme on 27 March 2003 at 17:37
    never done these before, never been asked for them!
    A customer wants solid letters fixed to a wall, no backboard sign to fix them to just single letters screwed into the brick wall, how do you do it, you must make a template of some discription to enable you to drill and fix into the wall so they all all straight and equally spaced ?
    Anyone know where I could buy the whole lot, cut out letters and all fixings needed as I don’t really know what I need for this job.
    I’d try to convince him of a different sign but nothing ventured nothing gained and I for one would like to know how to do it just in case I’m asked again
    Texcat replied 22 years, 9 months ago 5 Members · 7 Replies
  • 7 Replies
  • Simon Clayton
    27 March 2003 at 18:06
    It really depends on what type and size of letters he wants and what surface they will be applied to.
    MDF letters for instants can have brass studs fixed into the back, then matching holes drilled into the wall, fill these holes with grip fill/no nails or silicone and push letter into place, clean off excess silicone and its done.
    If the wall is flat rendered locator fixings could be used.
    Hope this helps and no doubt you will get lots of useful suggestion from everybody else.
  • Alan
    27 March 2003 at 18:23
    Just one link you may want to look at there are many more.
    http://www.neocrylic.com/letters.htm
  • Texcat
    28 March 2003 at 09:45
    Get yourself a copy of a sign mag, there are loads of trade only letter cutters out there.
    If you post exactly what materials you wish to use and the finish as well we can all advise you. If you do have any problems i can cut them, spray them or whatever finish, provide the fixings and a drilling template. We have a AXYZ 6010 router. 3x2m vacuum bed with auto tool changer so there are only a few (and i havent found them yet but we will) things we cannot do.
    We have done alot of 100mm acrylic letters with brass locators and then sprayed to finish. If colours came in 10mm all the better (only in 5mm) but we spray them after and get a great finish and effect. Especially when you put a chamfer on the edges.
    Keep us informed i am sure we can all help. Rob did a post on individual letters that is worth reading.
    Andy
  • t-winks
    28 March 2003 at 16:07
    We supply cut letters logo’s with fixings and templates in all amterials except s/s.
    Tell us the letter hight and material and we get straight back with a price.
    Tony
  • Texcat
    28 March 2003 at 16:16
    Sorry about my last post
    Re.We have done alot of 100mm acrylic letters.
    Make then 10mm and upwards. Can you imagine the price of 100mm acrylic sheet.
    Sorry
    If you can get it we could probably cut it.[/quote]
  • Joe McNamara
    1 April 2003 at 06:46
    Interesting to see that you spray the acrylic after you cut it Andy, what type of paint do you use and where does it come from?
    Joe
  • Texcat
    1 April 2003 at 14:29
    I use a company called
    Spraylat International
    Corby
    Northants
    01536 408409
    Excellent stuff, sticks to foams, acrylics with no prep.
    In aerosols or cans and will colour match.
    Andy
