Crop marks on large banners
Something I’ve always struggled with is trimming banners.
I give my banners a 5mm bleed and add crop marks directly in illustrator, but anything over 1.6m I struggle trimming as my ruler is not long enough. Yes, I could get a larger ruler but doesn’t help if the banner is 5 m long for instance.
I thought about adding crop marks along the edges every so often but just wondered what you guys do?
Currently, I give the banners a 5mm bleed and stroke the edge, I then just trim on that line but I have recently just started using the no hemming tape which I quite like actually but the trim marks need to be 100% spot on otherwise it makes the banner look untidy.
