Home Forums Software Discussions Signlab Software could anyone give me a few tips or advice how to create this
  • could anyone give me a few tips or advice how to create this
    Posted by Scott.Evans on 22 June 2007 at 09:19
    i need to make this logo.
    the problem iam having is making the band with "sausage specialists" and "quality meats LTD."
    i use sign lab 7.1 i need to have the line above and below the text to.
    could anyone give me a few tips or advice how to create this.
    been toying with this all day can get close to it but doesn’t look very professional
    thanks
    Scott.Evans replied 18 years, 5 months ago 5 Members · 6 Replies
  • Graeme Harrold
    22 June 2007 at 09:36
    I usually do all my design in Corel 12, however the principles should be the same. In Corel I would create an additional layer over the graphic and lay all the detail out to get the alignment similar. For something like that I would create the two ellipses first and align them to each other. At this point I may create a 3rd central ellipse for the text, however in this case I would align the text to the inner ellipse and adjust the offset to create the space.
    Once done, the ellipses are broken up to allow the remainder of the graphics to be inserted.
    Hopefully this will point you in the right direction.
  • Nick Minall
    22 June 2007 at 10:51
    Try drawing the ovals then type the text then if you go Transform fit text to arc or select the text and one of the ovals then Transform fit text to path.
  • Scott.Evans
    22 June 2007 at 18:02
    got it in the end.
    made an ellipse then put text to path and twigged with the settings.
    i was trying the arc method first couldn’t get anywhere with that.
    is there any way of opening a .cst file in signlab? if not dose any one know if there is a way of exporting from cut stdio (rolands software)
    thanks guys
  • Barbara Eden
    22 June 2007 at 20:30
    Scott, I don’t have the same Signlab version you do,but I got a download thingy from the Cadlink site that enables you to launch Signlab from your Corel programme.
    Don’t know if that’s any good to you 😕 😕
    Babs
    22 June 2007 at 20:35
    quote Barbara Eden:
    Babs
    Its basically a cut and paste shortcut, its been in signlab since version 5, I think. but I have had a few problems when using it, I find it better to export from corel, then import to signlab,,
  • Scott.Evans
    23 June 2007 at 14:51
    sorry its not a corel programme i have its cut studio come free when you buy a cutter of roland.
    the programme will only save as (*.cst ) format you Carnot export of it but you can import .eps .ai
    need a way to open (*.cst) in sign lab
    hope this had made it more clearer and hope there’s a way of doing it
