Home › Forums › Sign Making Discussions › General Sign Topics › Corner Rounding Tools?!?
Posted by BenRead on 19 October 2010 at 18:27Evening all,
I have a job that has come in where the customer specifically requires rounded corners, the job is big enough that is makes sense for us to buy a corner rounder.
What do you guys recommend?
I will be cutting lots of 10mm foamboard and dibond.
Thanks Ben
Martin Pearson replied 15 years, 2 months ago 9 Members · 10 Replies -
went to the nec interbuild show today. one thing that caught my eye was the exact saw. the smaller one will probably help with doing corners ad you can swerve the saw for curves but also has the capability to use various diffrnt discs for plastic to diabond and other composite boards : heres the site :
http://www.fredshed.co.uk/exaktps150saw.htm
(probably cheaper on ebay but just for info check the url above)the ps150 will do curves.
They are available from homebase for £90
http://www.homebase.co.uk/webapp/wcs/st … searchtext>EXACT+SAW&c_1=1%7Ccat_16849334%7CDIY+power+tools%7C14418763but not the tool for the job a corner rounder is far better
Not sure if I’m allowed to put the link so the item number is 260522037242 Flea-bay about £50 and cuts up to 10mm I think that you can also change the size of the corner with different type blades although not sure about that
Try the toolbar Ben as I am pretty sure there will be a number of suppliers, I know jag do them for starters.
I use one of the JAG ones all the time for 10mm and 5mm Foamex or similar. I have used it on dibond type material but I’m not sure how the blade would cope with repeated use.
Alan D -
http://www.presco-uk.com/index.php
http://www.chilvers.co.uk/index.php
http://www.joyce-pm.com/Joyce do the Warrior for £62.50 plus Free shipping.
i have two different ones from JAG. you can buy various sized cutting dies from them too.
http://www.jagsignsupplies.com/aqshop/c … php?id=982
Just ordered a corner pro 4.. lets see how it goes.
Thanks Again! Ben
Think you probably made the right choice Ben, had a look at the one Ray posted a number for and it looked to me like a paper cutting machine which I doubt wouldl be up to the job and I wouldn’t expect it to last to long if used on a regular basis.
