Home Forums Sign Making Discussions Neon, LED, Lighting corner rounder for DiBond
  • corner rounder for DiBond
    Posted by Neil Churchman on 6 November 2008 at 17:15
    anyone know if such a thing exists that can round off the corners of 3mm DiBond, just to finish of the sign, and so peeps don’t stab themselves on the corners 😮
    Neil Churchman replied 17 years, 1 month ago 9 Members · 9 Replies
  • 9 Replies
    6 November 2008 at 17:22
    Neil
    jagsignsupplies do one or
    http://www.joyce-pm.com/index.php?main_ … er+rounder
  • Peter Dee
    6 November 2008 at 17:24
    Draw an arc, hacksaw off the points close to the line and file to shape.
  • Dan Osterbery
    something round and a jigsaw?? that how we do it!!
  • Steve Underhill
    6 November 2008 at 17:45
    Rotozip rotary tool with angle grinder attachment,
    with a 2p piece stuck on the corners with double sided tape, very effective.
    Or you could try it like Me and Peter M did once when I didn’t have a rotozip and needed rounded corners in a hurry, and use a grinder in the wind, balanced on a black and decker workmate and one hold the corner of a 3 metre sheet of dibond onto the wheel, and one walk round the grinder until it falls off into your arm (not mine) and gashes it quite deeply.
    LOL
    Go with the rotozip every time now. :lol1:
  • Derek Heron
    6 November 2008 at 17:49
    i got one of these at sign uk
    used to file etc wouldnt be without this now does Magnets foam board diabond all with ease
    you can get diff radius corners
    http://www.jagsignsupplies.com/aqshop/c … .php?id=60
    corner rounder pro
    good solid piece of kit
    Derek
  • John Harding
    6 November 2008 at 17:52
    I use a file – doesnt take long – unless youre doing loads save your money
    John 😀
  • David Lowery
    6 November 2008 at 18:08
    I Got the CR1 from Jag with an extra larger cutter….Brilliant.
    Use it constantly.. Got 100 di-bond panels coming tomorrow and wouldn’t like to "file" or jigsaw that lot. Also you get a nice clean cut and no swarf that you would get filing or jigsawing.
  • Chris Windebank
    7 November 2008 at 08:12
    I brought the Warrior from Joyce and Co (Peter’s link) cuts dibond with ease. Comes supply with a 6mm radius corner rounder. Haggle though, usualyy go for 80.00 not 115.00 as on their site
  • Neil Churchman
    7 November 2008 at 08:42
    thanks to everyone for the replies – seems there’s quite a few to choose from depending on how much you want to spend.
    we normally just use the file to round off the corners, but as some of you pointed out in the responses, this can leave feathered edges and let’s be honest, no one wants to file off 200 corners on 50 signs with a file 🙁
    once again this forum has proved to be a gold mine of information and help – well done mods 😀
